Question about Curtis DVD1041 Player
My Curtis DVD1041 Player will not turn on
I just bout this Curtis dvd player and when I go to plug it in and press the power button it will not turn on. I've tried several different outlets but still run into the same problem.
  • 468 Answers
May be this li know to the online manual will help.
Bob
Curtis DVD1041 Instruction Manual
Posted on Jan 06, 2015
SOURCE: Curtis DVD-7620 (7600 series) Combo VHS / DVD Player - what is remote code?
It all depends on the brand of remote your trying to program,for a nexxtech the codes are one or the other 0929 or 0928.
Try typing in the search engine for example Curtis vcr/dvd7600 RCA universal remote codes. You may get better results.
I hope this helps you.
If not at least you will learn how to use the different code retreival methods they don't tell you in the booklets/pamplets that come with them or if you lost it.
Good luck
Posted on Nov 23, 2008
SOURCE: Curtis DVD 2100 DVD Player
Do you have the owner's manual?
If not, you can download it at www.curtisint.com at the support section search for "Manuals And Downloads" thumbnail at the top of the site, and then, search
for your model in the manual catalog as DVD 2100 and download it! It's in PDF format and you will need Adobe Reader if you don't have it, download it from www.adobe.com/reader .
For your solution:
- open your manual at P-35 GENERAL SETTINGS - "Restore Factory Settings".
- With the remote control, press "SETUP" and you should see a menu box with:
1- General Settings
2- Playback Settings
3- Record Settings
4- Language Settings
5- Channel Scan
6- Clock Settings
- Choose the General settings and then go to "Restore Factory Settings"
1. In the General Settings menu, use the or button to select
the Restore Factory Settings item and press the SELECT
button. The OSD will display as follows.
2. Use the or button to select OK .
3. Press the SELECT button to restore all default settings.
When your unit doesn't work properly, it may probably result
from some wrong settings. Please try the Restore Factory
Setting function to see if the unit can restore to its normal
I hope that will help you! If you need more details, don't hesitate to e-mail me!
lhupatech@globetrotter.net
Posted on Mar 20, 2009
  • 5 Answers
SOURCE: blinking light on curtis 1047 dvd player
Needs to be serviced.
Posted on Jun 27, 2009
pabloloco
  • 2335 Answers
SOURCE: I have a Curtis Progressive Scan DVD 1056.
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Curtis DVD player.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Posted on Apr 15, 2010
muntejaya
  • 10421 Answers
SOURCE: curtis DVD 1041 from KMart
Hello, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__e4re
Posted on Feb 27, 2011
I have a hisense hd lcd tv and I tried watching a dvd on my curtis dvd1041 dvd player and it only plays in black and white
Check to see if the DVD player has a NTSC / PAL switch. For North America it should be in the NTSC position, if it is in the PAL position you will get distorted and or Black / White video. This could also be a setting in the setup menu instead of a physical switch on the unit.
Nov 08, 2014 | Televison & Video
No setup screen/picture do ineed a digital converter? I think my tv is analog ifso where do I get one and about how mudh will it cost?
Your DVD1041 player, does not have a digital output. It is analog.
If your TV has a composite entry, or even an s-video entry, you can buy a cable.
When your TV has a scart entry you also can get a cable, but you need a plug from tulip to scart. And 3 tulip - tulip cables.
Or a cable with one end scary and other end tulip plugs. Best with a in / out switch on the scart plug.
Sep 29, 2014 | Curtis DVD1041 Player
Screen is red
replaced the main board.
Mar 24, 2014 | Curtis DVD1041 Player
Remote won't work but can manually operate
you do the camera tricks just to ensure if the infra red sensor of the remote is working. get a digital camera turn it on,then get the remote controller. press any button at the remote controller pointing to the digital camera, if you see a light at the display of the camera then the infra red sensor is good but if no light either the sensor is worn out or the circuit was defective.
Dec 07, 2012 | Curtis DVD1041 Player
My dvd curtis dvd1041b has a problem. when I turn off my DVD player, he switched back on in some second. what I must do to turn it off
Hello
Its power supply baord, and digital processing board should be suspected. The set need service.
Mar 06, 2012 | Curtis DVD1041 Player
I have a Vizio TV and comcast cable. I connected the red yello and white to each end, plugged in the curtis 1041d dvd player. The lights come on and the tray ejects and goes back in both manually and by...
there is a problems on the loding sensor swichtes there is two plastic toggle switch inside needs to clean it. used wd40 none static cleaner for electronics devices.
May 30, 2011 | Curtis DVD1041 Player
Curtis DVD1041 Player Logo
172 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
