Daewoo dwcld1013 Maschine is stuck up and shoowing 'OE' code on display screen. Please advise, how we can rectify this issue. Regards Ashfaq Mobile # 050-5482895 Dubai, UAE.
  • 6277 Answers
SOURCE: Dear Technician, I am using Bompani's
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 10, 2011
  • 106 Answers
SOURCE: I am getting an OE code on the display. I changed
Make sure you check to see if anything is caught inside the drain line, or the bottom bellow (black hose that connects from the tub to the drain pump/motor.)
Posted on Mar 29, 2010
MNTECH
  • 1543 Answers
SOURCE: my washing machine, which is a LG Intello Washer
That is actually a DE (drain error). Clean out the filter, located behind the access door on the bottom left side on front of the machine. If there was nothing in the filter, replace the pump motor.
Posted on Jan 31, 2011
Testimonial: "Thank You, it worked. Made the wife very happy. Thank you again."
FitzOriginal
  • 842 Answers
SOURCE: Daewoo DWCLD1013 washer & dryer The
The cycle that the machine is stuck in is in fact the empty cycle, just before the spin kicks in. It is staying there because it has a problem evacuating all the water. The machine won't go into spin until all the water is gone and after a set time ( 20 minutes is unusually long, most machines stop after about 10,, but I'm not familiar with Daewoo), the attempt to empty is aborted and the machine stops.
Your problem therefore is either:
The filter for the empty pump is clogged with debris (far and away the most likely) you will need to locate and clean the filter
The EXIT to the drain is blocked, check the empty pipe is not blocked
The empty pump has failed (you would usually expect to hear the pump rumming, but it may not be a noise that you are familiar with).
First and second items are easy to fix, the 3rd is a pump replacement, which isn't that hard, but depends on your level of DIY skill
Posted on Jun 23, 2011
caroldon
  • 17129 Answers
SOURCE: -I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
Posted on Nov 21, 2011
My daewoo washin machine shows error code OE & it wont work actually whats the problem ? tq
Error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. Remove the suspected hoses and clean out. Replace and your good to go.
Nov 21, 2016 | Daewoo Washing Machines
DAEWOO,WASHING MACHINE.CDW-WD13WCS/RCS. Door will
This video will show you how to open your DAEWOO washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 02, 2013 | Daewoo DW500M Top Load Washer
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Daewoo DWCLD1013 washer & dryer The cycle keeps getting stuck on spin at around 10minutes, at which time it keeps going round and round with no actual fast spinning, until it stops about 20 minutes...
Jun 23, 2011 | Washing Machines
OE code on front load Daewoo washing machine
According to your owners manual you only have two choices...
Your lint screen is blocked or you have a problem with your drain motor (a separate device ).
Old age & experience will add a third... Assume lint did get past all those sophisticated "filters" and is presently residing inside the impeller housing... In the olden days when those housings came apart (aluminum/aluminium) I took out an entire sock and enough lint to make another... My guess today is you buy another plastic pump.
Sorry I could not get part number or price here in the USA...
Not even cleverly saying "spares" (but I did try).
Hope this was helpful.
Daewoo Washer Drain Pump Spares Yahoo Video Search Results
Yahoo Image Search Results Page
Amazon com Daewoo Dwd m301wp Mini Drum Washing Machine English Menu...
http://www.daewooelecusa.com/customer-service/service-centers
Jan 06, 2010 | Daewoo DW500M Top Load Washer
OE error code for daewoo front load washer
error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.
Thanks
Dec 24, 2009 | Daewoo DW500M Top Load Washer
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
Machine display an error code sc 500
YOU MUST RESET machin by: press clear mode key(yellow)---enter 107 by keyboard----press clear/stop key (red) for4 seconds--- turn off machin and on
Dec 22, 2007 | Gestetner DSm615 Digital Imaging System
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
