Trying to remove the case of the es2 300x
I have been tring to remove the case from and old gateway desktop computer. it is a gateway es2 300x. i do not see any screws on the case and not sure if it slides or pulls up
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Look for a Black button on the front of the case (Not the power on button) push it, And the top of it should pop up, If it doesn't pop up lift it up.
Posted on Apr 26, 2014
  • 349 Answers
SOURCE: Remove Casing from Medion desktop
i suspect you need to slide off the top part of the case,their will be some wires attached to it.
good luck
Terry
Posted on Mar 01, 2008
SOURCE: tried to upgrade RAM on
thanks for the reply but no ideas what CMOS is and how to clear?
Posted on Sep 26, 2008
  • 82 Answers
SOURCE: I have a Gateway Desktop that is 6 years old. I
This procedure depends a lot on the exact configuration of your Gateway. They are good at making proprietary towers that are different from all others. Unplug all cords from the back of the computer. remove screws along the back on the side of the tower. ( Most of the time it is the right hand side if you are facing the back of the tower :) ) Pull back on the side panel. If it slides back then you're in!! Inside there should be two light or dark grey cables that are flat and about 2 inches wide. one will go up to the top of the tower to the cd player. the other will go down lower to a 1 inch thick rectangular device that is your hard drive. If you are trying to save your hd for use, then be careful at this point. If you are not then just tear away!! Remove the grey (IDE) cable from the back of the hd. Then remove the 1 inch wide white power cable connector that is now exposed on the other side of the ide cable. Good. Now here is where it can be very different depending on your model. The hd will either be screwed directly to the chassis on both sides, or it will be encased in a plastic sled device that will have a latch and will slide out. If it is in the sled, then locate the tab, push in, and pull back. Voila! HD is out. If it is screwed directly into the chassis, then you will need to take off the other side cover of the tower in order to access the screws on the other side of the HD. Then remove. If you are going to store for reuse, it is best to store in a static free bag, otherwise, dispose of according to local regulations for e-waste.
Posted on Mar 08, 2009
  • 2692 Answers
SOURCE: how do I remove the gateway computer case to install hardware?
Here is the gateway link Put your Serial number in and then download a manual for instructions.
http://support.gateway.com/support/drivers/dlcenter.asp
Posted on Mar 26, 2009
  • 341 Answers
SOURCE: Removing motherboard from Dell Dimension 3000 Desktop Case
Make sure that you have removed any add on cards that snap into the expansion slots on the motherboard. Some computers use these plastic standoffs that are used for alignment purposes and they protrude through the motherboard. You need to use some small needle nose pliers and pinch the plastic top piece together and then the board will be able to slip up and over them.
Posted on Jul 24, 2009
Where can i find a wire diagram for a Gateway FX6800-01e Core i7 Motherboard
http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm
Aug 16, 2014 | Acer Computers & Internet
My gateway profile 4 all in one has a totally white screen with no display. Rebooted with normal
before thinking about replacing the video card
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
if you need to replace the video card it will be attached to the rear of the vga lead inside your computer usually in a pga slot
Remove your computer's cables.
Turn your computer around so the back faces you.
Remove the two screws on the computer holding the right side of your computer to the case.
On many models of gateway computers, you only need to remove the screws with your hand. Remove the right side of the case to expose the interior.
Unscrew the metal plate of your old graphics card holding it to your computer's case. Remove the card by sliding it out of the motherboard.
Slide your new graphics card into the slot from where you removed the old one. Screw the metal plate to your computer's case.
Reassemble your computer and connect its cables
hope this helps
Aug 02, 2012 | Gateway Profile 4 All In One (MPN...
I installed a new motherboard for a Gateway DX4710-05 + windows vista.CPU will not turn on but i do get a continunous bipp sound.Thank you for your help.
In this case do the following steps .
First Remove your computer's RAM and try to switch on the computer . If even after removing the RAM your computer makes the same continus beep sound then just click the RAM properly and insert it properly.
If again you your the same noise then your RAM is faulty.
Jul 11, 2012 | Gateway DX4710-UB801A (L-1015700R) PC...
Trying to remove the hard drive in an old desktop, how do I do it?
Almost every computer manufacturer has their own way of installing hard drives on each system they make. You should look up your specific Gateway system at their website and look for service and support. There should be instructions posted. Given that Gateway is failing or has failed as a company there may not be any resources available. If that is the case you should take the computer to a computer service center for assistance.
Jul 27, 2011 | Gateway Computers & Internet
I am tring to remove the hard drive from a gateway 610xl desktop system. Do you know where I can get instruction on how to remove the hard drive?
cosmetic screw covers that cover nothing
"remove this panel so you can remove that panel so you can slide the
carriage holder and unscrew the fenortnor rods."
"Flex the case in the middle and the undercarriage will drop out."
"Slide the front cover a couple inches left and remove screws, then
turn it around and lift the cover one inch to remove third screw."
"Stroke the front left corner lightly, singing a lullaby, then flip it
over and scratch at the furry spot in the middle."
Feb 25, 2011 | Gateway Media Center 610XL PC Desktop
How to open gateway 300c desktop
There are several casings. You'll just have to pick one that fits your computer. Before you begin anything. Turn off your computer and remove the power cable. New Midtower Case 1 Look for a release handle on the top of the new midtower case. 2 Push the release handle inward. 3 Swing the case down from the top to open it. Microtower Case 1 Lay the computer down so that the left side is face up. 2 Locate two cover release levers on the back of the case toward the middle of the left side panel. 3 Squeeze the release levers together, then lift the panel up, swinging it away from the back of the case. Old Midtower Case 1 Lay the computer on its side, so that the left side panel is face up. 2 Remove any retaining screws along the left side of the back of the case that are holding the panel in place. These screws may be removed with your fingers. 3 Locate two release levers at the top and bottom of the back side of the case, and push them away from each other. 5 Swing the panel up and away from the case to open it while holding the release levers.
Jan 01, 2011 | Gateway 300 C PC Desktop
How do i remove the case on my gateway pc
Hi:
Here is the link to the user guide for your computer. It includes a section on upgrading, and how to open the case!
http://support.gateway.com/s/Manuals/Desktops/9525329.pdf
Mar 24, 2010 | Gateway E-4100-H2 (E4100H2-D) PC Desktop
Added Memory, Now Computer doesn't Boot! HELP!
Either you have defective SDRAM chips, or your CPU was damaged when you installed them .. in either case, your only solution is to have the problem diagnosed by a professional.
May 26, 2009 | Gateway 500 CS PC Desktop
How do I remove the gateway computer case to install hardware?
Mar 26, 2009 | Gateway Essential 400 PC Desktop
How do I install a power supply in a gateway 610xl computer?
REMOVE THE CASE AND UNPLUG ALL.THERE SHOULD BE 4 SCREWS HOLDING IT IN PLACE REMOVE THEM.REINSTALL NEW IN REVERSE.RICHARDM69
Nov 26, 2008 | Gateway Media Center 610XL PC Desktop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
