How to enter "service mode" on ineo 165 please?
I have error : call service maintenance M1 in my Printer. I've already replace the drum and developer. But the error "call service maintenance" still appears. So, how should I proceed to resolve it? My friend tells me that I should enter to "service mode" but I don't know how...
  • 10 Answers
SOURCE: Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Posted on Mar 12, 2008
  • 4 Answers
SOURCE: develop ineo 161
open then close the front door -> the display show " CHANGE DRUM ? YES/NO " -> press yes on the board
Posted on Mar 13, 2008
  • 191 Answers
SOURCE: how to get into the service mode
press button C & 8 at the same time to show u the error no. its the error no that will let u know the fault type.
Posted on Sep 29, 2008
  • 7 Answers
SOURCE: reset drum copier develop ineo 161
1 Press the [Utility] key three times.
“USER MANAGEMENT” appears.
2 Press the [Yes] key.
"CHANGE D/C" appears
3 Press the [Yes] key.
Your done.
Posted on Jul 13, 2009
pineworks
  • 4041 Answers
SOURCE: Service error 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 22, 2010
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Sep 29, 2016 | Konica Minolta Office Equipment & Supplies
How do I clear maintenance call M2 in copier Ineo 165
menu stop 00 stop 01 go to service choise go to maintenanc 0 presss back go to iu life stop mode press continues and press back sit down to clear data go to maintenanc clear prees ok and supplies clear and press ok .powe off and on and isssss okk :)
May 26, 2014 | Konica Minolta Office Equipment & Supplies
Ineo 161 codice sblocco chiamare service m1
GO to service mode a clear consumable counter to clear M-1. It is a maintenance counter that was set up to monitor a part
Apr 15, 2014 | Minolta Office Equipment & Supplies
Machine error 28
Well it's a low temp error for the fusing assembly. Sounds like you already had it in Maintenance Mode. Sometimes those errors can only be cleared out by entering maintenance mode and pressing 9,9 to exit out. Should then start the normal warm up procedure. If the problem continues then reseat the fuser or take it out and measure for continuity across the lamp and thermostat. The service manual also recommends checking the line voltage. Basically make sure it's plugged straight into a wall outlet and no other large power sources on the same circuit. Example, another copier or this time of the year a small space heater.
Maintenance Mode enterance Press Menu/Set and Black start button and Up arrow 4 times. Machine will read Maintenance on the display if done correctly. Press 9,9 to exit of the mode and the machine will attempt to restart normally.
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Feb 11, 2014 | Brother MFC-9420CN All-In-One Laser...
How to enter into service mode ricoh 8300dn
Ricoh SP8300 SP mode (Service Mode)
To Enter SP Mode (Service Mode)
Do one of the following:
If the power is already ON, press the "Home" and
"Simple screen" keys at the same time for more
than 3 seconds, and then press the "User tool"
key.
or
If the printer is OFF Press the "Home" and "Suspend" keys at the
same time while turning the main switch on.
Reset for Maintenance Kit A or Maintenance Kit B
So the "Replace Maintenance Kit A" or Replace Maintenance B" message will go away.
Once in SP Mode (Service Mode) press the following:
"ENGINE"
"SP-7XXX" - "DATA LOG"
"7804" - "PM Counter Reset"
"6" - "ALL CLEAR"
"EXECUTE"
Jan 13, 2014 | Office Equipment & Supplies
Minolta DI1611 M1, M2
replace the drum cartridge, also clear maintenance counters in service mode
Dec 23, 2013 | Konica Minolta Office Equipment & Supplies
Clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Apr 09, 2010 | Brother DCP 165C Compact Color Inkjet...
HI THERE , I GOT ONE PROBLEM IN BIZHUB250B ERROR C2557 .. I PUT OLD DRUM,DEVELOPERAND I RESERT F8 AND RESERT COUNTER STILL ERROR CODE IS THERE , AND ALSO PUT NEW PARTS DRUM DEVELOPER, ATDC STILL THE SAME...
1.press the utility button
2.meter count and details button
3.enter tech rep mode: stop,0,0,stop,01
4.select tech rep choice mode
5.select printer tab
6.select atdc sensor gain
7.set value to 165
back out to the ready screen then power off then on the machine have done this many times and just fixed one today with the same problem
Nov 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Error message M1
Press Utility / Counter -> {STOP}{0}{0}{STOP}{0}{1}, now you should be in Service Mode. Go to Service Choice - > IU LIFE STOP MODE -> and choose CONTINUOUS.
Mar 19, 2009 | Konica Minolta bizhub 180 All-In-One...
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
361 people viewed this question
jasbo
jasbo
