Question about Maytag MEW6630DDB Electric 30 in Double Wall Oven
Hi. When you turn on the top oven the upper element doesn't shut off after it gets to the set temp.
I can shut the oven off with the control panel. Everything else works. I reset the breaker, but the problem remains. Bottom oven is fine. Got any advice?
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 650 Answers
It could be a stuck or welded relay in the control board. Sometimes a sharp rap on the relays on the control board will jar the contacts loose. Be careful not to tap too hard and make sure the power is off. If this doesn't solve the problem you may have to replace the control board.
Posted on Apr 02, 2014
aborcass
  • 2651 Answers
SOURCE: heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Posted on Mar 25, 2008
Krazytech
  • 725 Answers
SOURCE: maytag gas oven mgr5770abb
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Posted on Aug 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: top oven appears to have no power going to it.
Contact an electrician and or the power company.
I believe you have lost the neutral/ground in your power service.
Posted on Feb 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: electric oven. temperature problem
Change the temp sensor.
localwonder
  • 6784 Answers
SOURCE: oven will not turn from top panel electric panel is stuck on 5a6
Unplug this unit for 3 minutes. if the control fault still exists after the 3 minute reset, replace the affected control board.
Posted on Jun 03, 2009
Have a ge truetemp double oven model jkp27boa2bb. The control panel does not work. Turn the temp knob for lower oven and upper oven lite comes on. Is the control panel bad? Lower oven heats up only
The heating element on the top part off oven might be bad or a fuse that's located on back of oven either on or behind back panel.
Mar 16, 2016 | GE Ovens
Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
Oct 28, 2014 | Ovens
Broiler turns to pre heatworks oven doesnt heat when temp
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 15, 2014 | Kenmore Ovens
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Upper element stays on
Check out this tip... it willhelp you to understand what is happening..
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Mar 23, 2010 | Ovens
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Top oven will not heat up
    Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
    Nov 14, 2007 | GE JKP45 Electric Double Oven
    Maytag MEW6630DDB Electric 30 in Double Wall Oven Logo
    Top Maytag Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Mack Baxter
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
