Question about Reizen Atomic Talking Clock
Ken-tech T-4639 weather station not receiving signal from outside unit
I received a Ken-Tech weather station T-4639. The base is not receiving the signal from the outside unit so no outside statistics are showing on the base. The units are both set to the same channel. I have tried taking the batteries out and reinstalling them. How can I get the two units to communicate?
My sensor isn't sending signals to main unit for outside temperature .This unit is brand new and has new batteries
  • Remove all batteries from both units
  • Install batteries in sender. Allow time for sender to initialize and begin sending signal
  • Install batteries in receiver. You should see outside temperature displayed
Dec 29, 2016 | Measuring Tools & Sensors
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
I am unable to get the remote temperature to show on the base unit. It appears that there is no signal.
In general, batteries are installed in the remote transmitter first and time is allowed for the transmitter to begin sending data. Batteries are installed in the receiver next and you should see the outside temperature displayed.
Dec 25, 2014 | Measuring Tools & Sensors
I have model 9630 The Weather Channel. I was not receiving the outside temp so I replaced the batteries in both units. After several trys it's still not working. The receiver shows OF.L for the inside
  • Remove batteries from both units
  • Install batteries in outside unit and allow time for it to begin transmitting date
  • Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit may be defective.
Oct 31, 2017 | Measuring Tools & Sensors
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
Jul 01, 2014 | Acu-Rite Acurite Wireless Weather...
Auriol 4-LD3091 weather station will not pick up sensor
I had the same problem and gave up on the unit for a while, then I had another attempt and found this worked for me. Take the batteries out of both units (receiver and outside sender) then reinsert the batteries BUT put the batteries into the outside sender unit FIRST, this seems to make the difference as when you then put the batteries into the indoor base-station it detects the outside temperature signal immediately as it starts to set itself up .
Aug 18, 2012 | Measuring Tools & Sensors
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
Acu-Rite 00754 Wireless Weather Station manual
The main thing with this unit is to put the batteries in the transmitter first, then in the base receiving unit. Then you can't really make any setting changes until the unit figures out the correct time through the radio signals it receives from Colorado, or wherever they come from.
Aug 27, 2010 | Office Equipment & Supplies
Reizen Atomic Talking Clock Logo
56 people viewed this question
Top Reizen Measuring Tools & Sensors Experts
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you a Reizen Measuring Tool and Sensor Expert? Answer questions, earn points and help others
