Question about Cooktops
Replace viking 12,000 btu valve with a 8,000 btu valve
The valve for my cooktop are discontinued by Viking. wouldl it be safe to replace the faulty 12,000 btu valve(pa010062) with a 8,000 btu valve(pa010061)? My first thought is that it would be safe but the output would be that of 8,000 btu making it a less powerfull burner. I normally cook on low to to medium with that burner so the lower btu should not affect my cooking negitively any thoughts or experences?
  • Cooktops Master
  • 842 Answers
Safety factors first, gas comes out of the tube the burner valve is mounted on, so double check all connections first. (Use liquid soap to test) With that being said, although Viking does produce this part anymore, the body of the valve would be the same in turning and interior function. I had to rebuild a valve in the past and still works to this day. So this decision is all yours to make, as a certified service tech and if this was in my home yes I would, but I could not do this for a customer.
I hope this helps
Posted on Apr 02, 2014
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Home™ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
Removing spark module viking gas cooktop
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
Apr 01, 2014 | Viking 37 in. VGSU161 Gas Cooktop
Vgsu160 6b
You can try some appliance parts distributors
Jan 17, 2014 | Cooktops
Viking cooktop DECU165-5B stainless seperated from
It can cause a fire. The same thing happened to me fortunately I ha dthe extended warrantee and it was covered. This is a common problem and should be addressed by Viking. After all it is not a cheap appliance.
Jul 21, 2010 | Viking 31 in. DECU165 Electric Cooktop
I hav a Viking professional. Only one burner ignites.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
Viking 37 in. VGSU161 Gas Cooktop looking to replace the grates any help?
LOCATE A SECOND HAND GAS OVEN STORE AND LOOK FOR ANY GRATES I AM SURE THE OWNER CAN LOCATE GRATES FOR YOU GOOD LUCK.
Nov 17, 2009 | Viking 37 in. VGSU161 Gas Cooktop
My VIKING 31" VGSU 101 GAS COOKTOP. All 4 burners can't ignite .If I light it will work
I have the exact same problem, same model. Read the instructions on this website for replacing the ignitors...looks complicated, also generic to all Viking cooktops. Let's see what we response we get.
Oct 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking Gas Cooktop replacement parts
The only way you can get part is through Viking I do viking warranty work for them and you have to call customer service to order parts
Jan 22, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Only 1 of 5 burners is working on my Viking electric cooktop
By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
Dec 25, 2008 | Viking 31 in. DECU165 Electric Cooktop
Ignite problem
imfornu, under each burner control is a valve and a switch that controls the spark to each burner. Sometimes these switches become wet or short out. In this case it sounds like yours is shorted in the closed position and therefore the spark. These switches run on a harness across each burner control valve..I believe the part number is PG220020, you can look it up on the net to get an idea of what it looks like...Catriver..post back.
Sep 05, 2006 | Viking 31 in. VGSU101 Gas Cooktop
Cooktops Logo
153 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
