Question about Electrolux Guardian Bagged Canister Vacuum
How do I dissasemble Electrolux EL4101A?
How do I remove the cover
There is a buton that you press on one side or the other of the cover and when you press it and hold it down you should be able to pull the cover right off
Posted on Mar 28, 2014
How to replace an electrolux 6500 epic motor
To get to the motor you will need to remove the top cover. Take the rubber cover off each side of the vacuum to reveal the piece of plastic that is holding the top and bottom together. Pull the plastic piece on each side out to slide it out, remove the top so you can get to the motor.
Jan 22, 2018 | Electrolux Vacuums
I need to find out how to open the cover to change the motor filter on my Electrolux Epic Series 6500 sr canister vacuum.
There is not a replaceable motor filter inside the body of the vacuum. There is an exhaust filter under the cover on top which can be removed by pushing a little tab at the rear of the cover.
Nov 15, 2017 | Electrolux Vacuums
Electrolux model el6984a how to remove cover
the rubber sile slide off.Please be very careful as the winder is controlled by a metal coil and is under a little of pressue and very sharp.....
Jun 16, 2014 | Electrolux UltraLux 2000 Bagged Canister...
C 153c how to dissasemble
Turn Body on it's top so bottom is facing up. Remove all screws around the perimeter of the vacuum. Turn vac over and slide entire top off of the body exposing the cordwinder. Voila!
It's probably just stuck! Hope that helps!
Jun 15, 2014 | Electrolux Guardian Bagged Canister Vacuum
Dissasemble System 90 Electolux
on the side of the vacuum there are rubber guards.These slide off....pull them off with a pair of needle nose.pull the slides off from the front. then open the front cover,at the bottom there are a couple little "nibs" that hold front off..Gently put a flat screw driver in and pull up..The machine will then be readt to open.best way is to put machine upside down and take the bottom off...
Jun 12, 2014 | Electrolux UltraLux 2000 Bagged Canister...
How is the motor cover removed?
Two screws at the front, accessed by opening the dust bag lid. Two screws at the rear accessed by prising off the on/off switch and rewind button covers.
Jan 05, 2010 | Electrolux Vacuums
How replace lightbulb on carpet beater (Electrolux central vac). Can't find any screws near light
To replace the bulb you will have to remove the power nozzle cover. Remove the cover by extracting the screws from the bottom. Take notice of which screw comes from which hole. Depending on the year, one screw may be shorter than the others. If put back in the wrong place, the screw will come through the cover when replaced. Once the cover is removed it's easy to replace the bulb. Make sure everything is lined up when reassembling.
Dec 30, 2009 | Electrolux Centralux Vacuum
How to remove the motor cover?
There are 2 screw under the removable outlet cover and 2 more under the shiny label under the booster slider. Pick off the label to find them.
Dec 05, 2009 | Electrolux Vacuums
Can't remove motor cover for electrolux EL2050
usually there are screws on the bottom, normally 6-12 screws. Once they are out, there may tabs on the outside of the base fram, lightly use two flat head screw drivers and pull the cover away from the base.. be gentle as this plastic is thin, and could break. You will also need to make sure that the handle assembly is in the down position as the cover can get caught up in the handle when you try to remove it.
Jan 20, 2009 | Electrolux Vacuums
Cover won't close
Try removing the bag and closing the cover. Unless that piece that holds the bag has gotten loose, there isn't anything that should prevent that cover from shutting, so it may just be the way the bag is sitting.
May 03, 2008 | Electrolux Harmony Canister Vacuum -...
Electrolux Guardian Bagged Canister Vacuum Logo
97 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
