Question about John Deere Garden
I need to clean an air filter for a john deere 55ev chainsaw
It runs fine without the filter but when I put it on it bogs down and when I take it back off it runs fine again.
    Scholar:
  • 128 Answers
Just wash filter in petrol and blow of with compressed air , I would also remove spark arrester from exhaust and clean that by burning carbon of then blowing with compressed air , if you chainsaw still runs bad it needs carby serviced and retuned .
Posted on Mar 28, 2014
Testimonial: "I'll let you know if it works"
  • 1 more comment
  • cals-studio Mar 28, 2014
    just a note to cleaning filter if sponge type make a clenched fist after soking in fuel and squesh fuel out and spray air down through your closed fist to rmaove all petrol . and aloow to dry first .
    And remove petorl and allow to dry first .dd a Comment
    my computor can't spell
  • 16 Answers
SOURCE: my 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Posted on Jan 19, 2009
  • 4 Answers
SOURCE: Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
Posted on Jun 04, 2009
Jim1969pa3
  • 152 Answers
SOURCE: Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Posted on Dec 23, 2009
  • 132 Answers
SOURCE: while cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Posted on Jan 02, 2010
rollercam351
SOURCE: Have a McCulloch 3818 chainsaw.
Had this problem with my saw (3818) there are two adjustment screws on the side of the carb there is a hole in the plastic to get to them just fwd of the choke slide, not the idle adjustment which is farther fwd of the other. take a 1/8" flat head screwdriver, get the saw running and turn them ever so slightly till you can get a good idle, they only have a 1/2 turn of adjustment each, it doesnt take much
Posted on Jan 14, 2010
Have a John Deere La125 with only 13 hrs on it. Starts, but won't go in to fast throttle without wanting to die. It seems to be running a little rough in just idle mode. What could the problem be?
Hi Marsha:
If you've been running in a dusty situation it may be that the air filter is clogged. There should be a cover that you can remove to get at the filter. Remove it and give it a good clean.
I may be frowned on for this suggestion, but if you have blown or vacuumed it so it's nice and clean, start it up without the filter, just for a minute, and see how it runs.
Re-install the filter before you go back to work.
May 28, 2015 | John Deere Garden
Lawn mowers
clean air filter, clean out carby bowl and main jet
Jun 03, 2013 | Garden
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
FC540v Kawasaki john Deere 265, bugs down under load,emitting black smoke & then dies. Works fine without air filter.Carb cleaned, Compression check has 80 lbs
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Thanks for your attention to this matter.
Aug 29, 2012 | Cars & Trucks
I have an older john deere stx38. engine starts and runs fine, engage the blades and and engine does not bog down. with the clutch engaged, the shifter moves through the gears smoothly. left the clutch...
I had a similar problem and it turned out to be the automatic belt tension was blocked with grass so it was not tensioning the belt correctly. It was quite difficult to completely clean it but it has been fine ever since.
Jul 08, 2017 | John Deere 420,1020,2010,2020,2510,2520...
Bogs down?
Try turning the "H" needle CCW a little. Cleaning the muffler and spark arrestor is a good idea too (if it cannot exhale it cannot inhale).
I do not think you need this but something to save for later.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
65 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
