Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
HOW DO YOU PUT FUEL IN BULB AFTER YOU PUT NEW ONE ON
    Scholar:
  • 81 Answers
If you are asking about the primer bulb, you don't put fuel in it, you push on the bulb and the fuel is suctioned into the bulb via gas hose from the gas tank. If you don' see gas flowing into the primer bulb when it is pressed, then you have either installed it incorrectly or your carb needs to be cleaned.
Posted on Jun 15, 2009
Primer bulb not pumping fuel,new bulb !
are you sure you put it on the proper direction . they only work one way normally
Feb 16, 2017 | Garden
Replaced bulb and now it leaks elsewhere and wont fill bulb. How do i put it back together properly? Poulan pro pp025
if by bulb your referring to fuel primer bulb, I do believe that poulan uses a two screw clamp system , that has a ring that surrounds the primer bulb , on these it's critical that you get a perfect replacement bulb as size on this is critical for fit, there is a machined groove that edge of new bulb fits down into , make sure it's down in that groove before you very carefully lower clamp ring down over it and even more carefully tighten two screws with a Phillips head driver , if it pops out and you clamp down on that edge it cuts new bulb and you'll s**k air not fuel , once it cuts edge you'll have to start all over again with a new one
May 26, 2015 | Garden
I've got a poulan wild thing. That was running perfect until the primer bulb got a hole in and was leaking fuel. I went and got a new bulb, and in a hurry and stupidly put it in backwards. Pumped it u
You should have hurt anything, just remove and reinstall properly. Kind of hard to do this, but I guess its possible. If the new one is damaged get a new one. All it does is retain a small amount of fuel and always you to prime the fuel system
Jan 07, 2015 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Gas leaks from primer bulb
Go to a store that sells your brand of mower and get a new bulb. Be sure to put the fuel lines on just like they came off the old bulb.Draw yourself a picture of the lines on the old bulb so you are sure to put them back on properly.
Sep 28, 2014 | Garden
New primer bulb but engine won't prime
remove and clean the carby. clean out the main jet. ensure that there is nothing stopping the primer circuit from working. There are two valves under the primer bulb and a spring. when you push in the bulb fuel is squirted into the manifold When you take your finger off the bulb the spring pushes it out and new fuel is drawn past a valve to fill under the bulb. Pushing in again closes that valve and opens a second valve which allows the fuel into the manifold again
Apr 26, 2013 | Garden
90HP Yamaha won't turn over
It sounds like you have a air line busted somewhere i had one of my outboards do that it wouldnt prime for anything so i ran everything down checked the fuel pump and cleaned that out tore apart the carbs cleaned them bought brand new fuel hose still scratching my head i took off the air lines for the carbs and put new ones worked like a champ
Aug 22, 2012 | Boating
I have a homelite ut20585 string trimmer that i have put a new primer bulb, fuel lines and fuel filter on. i have checked the spark plug and it is good. i cannot get it to fire and run.
Ok you have to be 100% certain that you reassembled those hoses correctly, if any one of them is incorrect you are dead in the water as far as getting fuel properly. Tell me 2 things, Why did you feel they needed to be changed? and now that you've done it does the new primer bulb pump fuel at all, and maintain a full bulb of fuel after 15 min?
May 11, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
It wouldn't run when I got it gas was leaking put new fuel lines on put carb kit in still will not run acts like not getting fuel
is the primer bulb full & stays full when trying to run it if not the the diaphram in carb is bad needs to be replaced or primer bulb itself has a leak
Nov 10, 2009 | Garden
Trying to put new fuel lines in all around... bulb has two connections, tank and carb. carb has two connections, I imagine that the tank/filter line goes into the carb, carb then goes out to bulb, bulb...
Fuel routing:
Tank to carb (filter on free end in tank, replace annually)
Carb to primer (primer sucks fuel through carb)
Primer to tank (primer returns excess fuel to tank) HTH
Lou
Oct 11, 2009 | Poulan Garden
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
161 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
