Question about Bosch Microwave Ovens
On - off. switch
On off. switch does not work from grill and microwave
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 119 Answers
Need model number
Posted on Mar 31, 2014
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
CATA MC25SS microwave not heating
Usually when a microwave's fuse blows, it will be dead, not partially functioning.
It may be a bad door switch or mount.
(Anybody in the home opening the door while it's cooking?)
See our help file on door switches here.
Feb 25, 2013 | Microwave Ovens
Microwave HT85G650B keeps switching off after 2 secs when on microwave setting but works okay when on grill setting
grill circuitry is not the same as microwave circuitry. The microwave function relies on a magnetron to excite the water molecules in your food. The magnetron and high voltage diode are not working and need to be replaced.
Apr 12, 2011 | Bosch Microwave Ovens
Microwave will not start when time is entered and start is pushed
You got it! One of the door switches is not activating. Take a look at the door itself first. There should be two tabs that stick out. These tabs will engage in the holes near the control panel. If the door does not have a broken tab then the problem is behind the control panel on one of the switches. There are 3 switches back there.
Unplug the power cord, it is usually in the cabinet above the microwave oven. Then take the grille off the top, the screws for the grille are on the top of the unit facing down. With the grill off you will see the one screw on top of the control panel, remove that screw and lift up and out on the control panel this will give you access to view the switches and test them with an ohmmeter.
May 02, 2010 | Kenmore 60654 Microwave Oven
Sharp microwave grill and oven working ok, microwave option not
the magnatron is burnt out they are very expensive to replqace thus i would suggest bying a new microwave
Apr 21, 2010 | Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Tesco Combi Microwave-doesn't cook but grills ok
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 08, 2009 | Emerson MW8777W Microwave Oven
Smeg fmc24x oven and grill work turntable and microwave dont
I have a simular model and I found that the circuit board has three black relays, one for the grill one for the convection and one for the microwave. I found that the microwave one wasnt working so by swaping the microwave one with the convection one I got it to work and then replaced the faulty one with a new one at a later date.
Dec 03, 2008 | Microwave Ovens
Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Sharp R-303CW Convection / Microwave Oven
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
