Question about MSI A78M-E35 Micro ATX AMD Motherboard
Where is CMOS located on a MSI A78M-E45 FM2 motherboard
I need to reset because after Bios all of my USB ports lose power and My keyboard and mouse dont work to install Windows 7.
  • 400 Answers
I went to MSI website and found manual, downloads, support:
http://us.msi.com/product/mb/A78ME35.html#/?div=Manual
I am assuming your problem is changes you made in configuration, and need to reset. You should be able to find info here. I hope this is helpful.
Posted on Mar 28, 2014
  • Ryan
    Ryan Mar 31, 2014
    Problem solved. I needed to update my chip set. I had to use an old PS/2 keyboard and navigate the disc that came with the motherboard without a mouse, which was difficult because im a noob and this was my first build. Once the chip set was updated windows recognized my usb ports.
3 Suggested Answers
  • 10406 Answers
SOURCE: Mouse & keyboard not working
You're "stuck" -- if the circuitry for the PS/2 keyboard and mouse is not working, and if it does not recognize a USB keyboard, the motherboard must be replaced (by an identical moetherboard, if you can find one, or a "newer/better" motherboard that takes the same CPU and RAM as your current motherboard).
Posted on Jul 30, 2010
byteguy
  • 2229 Answers
SOURCE: MSI usb problems
Sounds like your O/S was damaged when the old MB failed. I'd boot the computer with yoru system disk and run a scandisk or, in the case of Win Vista or 7, choose the option to repair Windows.
Posted on Mar 22, 2012
How to recover Motherboard Bios?
Bios updates are dangerous because losing power can result in a dead mo bo. All U can do now is try to get another loaded bios chip for your motherboard.
Oct 17, 2015 | MSI FM2-A55M-E33 Socket FM2 mATX...
Unable to POST MB
Try first resetting your BIOS configuration to bring it to its default settings and that should do the trick....
Hope that helps.........
Jul 06, 2008 | Intel Motherboard
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
My USB is disabled on BIOS. I cannot use my keyboard/mouse (usb) when the computer start. I have no access to my BIOS due my motherboard has no PS2 keyboard connection. How to get access to my BIOS...
Hello
Reseting of your motherboard is the only solution for that problem. All you have to do is clear the CMOs battery of your motherboard. Turn off your computer then remove from the power plug or to a AC plug. Then remove the CMOS battery from the motherboard after five second return the CMOS battery to the motherboard. Plug in your computer to a AC power then power on the unit, then push delete while booting up now you can change the setting of your USB setting on the BIOS.
Hope this solution will help you.Keep on touch. Have a nice day and best regards
Sep 07, 2011 | Intel BLKDP67BAB3 Socket 1155Intel...
My system does not read any usb port frivers
Enter the BIOS/CMOS by hitting the appropriate key, during the Power On Self Test. Delete or F12.
Once in the BIOS/CMOS find the option to enable USB support for both 1.1 and 2.0 USB versions. Also enable the option for USB keyboard/Mouse support!
This should sort the problem out!
Give me a shout if you need further assistance, I am here to help!
Thanking you
damnor01
Dec 13, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Jul 30, 2010 | MSI PM8M-V Motherboard
Powers up no video and mouse stays lit when powers off
This is an old motherboard, with this in mind there are a couple things for you to try. Power off the system and unplug the power cable from the power supply. Remove the left side of you're case. Touch any metal surface to discharge possible static.
First clear the cmos jumper on the motherboard. See page 1-17 in you're manual for the location of the cmos battery and cmos jumper. Also see page 1-21 to clear / reset the cmos battery. (Don't forget to set the jumper back to normal after 30 seconds.
Doing this will reset the bios to its default setting.
If you added a graphics card to one of the PCI slots remove it.
(For now).
Re-connect the power cord for the power supply and power-on the system. If the motherboards built in VGA controller is working you should have display on your monitor and since we cleared the cmos the bios will want you to enter the bios to adjust all its settings.
If you do not have display than the onboard controller is defective. You can add a PCI video card into any one of the 3 (White in color PCI slots). It’s not uncommon for the mouse to stay lit. If you're mouse is plugged into a PS-2 port try un-plugging it when the system is off.
Then re-connect it with the system off. You can also buy a USB to PS-2 adapter. Most new mice and keyboards come with this type of adapter. See the link provided; http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=776087&CatId=469
If you're mouse and keyboard are PS-2 and connects to the system by USB, try another opened USB port. The next link opends to Biostar and you're motherboard;
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=324
Cheers'
Mike
Mar 08, 2010 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Dell XPS 400 no power to usb
Cant remember the exact location for this, but you need to access the CMOS config when starting up. Dig around a little and you will find the settings that will allow you to start you system with a usb mouse and keyboard.
Hope this helps. If you have any idea where I can get drivers for my motherboard (EPoX EP-4PDA5) that would be great. I already tried EPOX's website, and no joy.
Cheers
Jan 08, 2009 | Dell (002TR) Motherboard
Asus P4p800 se Mainboard USb Ports not working
it would seem that you are not the only one with this problem with the USB's, the only soloution i have found that people say works is to reset the cmos (remove motherboard battery without any power cord attached) for 10 mins, or, go into the bios and reset to default/optomised defaults
hope this helps
kind regards
Nov 18, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Problem
That particular board has PS2 ports on it. I would suggest a couple of things. If you have a PS2 keyboard, plug it in and use it since legacy USB support might not be turned on in BIOS.
If that works, go into BIOS and turn on legacy USB support and then try the USB KB again.
Secondly, if you don't have a PS2 keyboard, get your manual out and clear the CMOS. It might be that the legacy USB is turned off and clearing the CMOS will re-enable that (assuming it is done at the factory).
Good luch.
Mar 19, 2008 | Biostar P4M890-M7 Motherboard
MSI A78M-E35 Micro ATX AMD Motherboard Logo
242 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
