Sanyo pdp 42xr8da
My Sanyo Plasma is stuck on AV. I tried to switch from HDMI 2 to D-sub and it went to AV (only selectable option) and wont change. HDMI 2 was working at the time.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Change memory ic else
problem in av hdmi change over section inbuilt in processor
Posted on Apr 29, 2014
3 Suggested Answers
SOURCE: Model: Sanyo PIP MTS Stereo/SAP/dbx
Stayingh on blue screen with video 1. Do not have remote
Posted on Jun 12, 2011
SOURCE: Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Posted on Apr 12, 2013
My Sanyo tv stuck in Please Select Language screen. I have unplugged tv, changed batteries in remote. I'm also am stuck. Tv is a year old. No power outages either.
Depending on the unit you have if you have more than one input (mine has four HDMI, Computer, Standard TV, etc) you may need to be on the right channel or input. You should be able to bring up an On Screen Display that will let you make changes, You might want to try the Menu key on the remote to bring this up. If nothing else go to http://sanyo-av.com/support/ and find your TV and look at the manual.
Jan 26, 2017 | Sanyo Televison & Video
How do you enable the pioneer plasma pdp ro6fe HDMI settings? My HDMI input options do not currently allow selection & adustment
just plug in the HDMI cable from what ever equipment your using,then switch it on, put the other end into the back of the tv, take out any scart cables you have plugged in, just for now.
then find your AV source button on your remote, press it until it says HDMI.
the chances are,if it flickers or wont show, then you'll need to hook up the external equipment by scart cable & go into the picture settings & change it to a lower rez. (The tv wont be the problem)
i can't help you any more because you haven't said what it is your trying to do or hook up.....SKY BOX, DVD PLAYER, GAMES CONSOLE...e.t.c.
Or what make of TV it is.....
Sep 10, 2011 | Televison & Video
How do i connect to pc using hdmi cabel its a sanyo pdp-42xr9da lcd
You have a cable called as the DVI-D to HDMI cable. Using this cable you can connect PC to LCD.
You have a HDMI port on left side of your LCD.
For easy understanding i am attaching a image.
Jul 24, 2010 | Sanyo DP42746 42 in. Plasma Television
Cant get my tv to display my dvd player.when i hook the jacks to tv it doesnt work,the jacks are red,white and yellow
look at the point where you are trying to put the plugs into the tv are you matching colours if so are you sure its an input .?? ..... the easiest way is to use the inputs at the front of the tv(if it has one) and change it through your AV channels (hopefully you knew to chage to av?
Dec 15, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Need manual for flat screen model pdp 42xr8da
Are you referring to the owners manual or svc manual?
Feb 28, 2009 | Televison & Video
We have just brought a PDP-42XR8DA plasma tv, once set up and all tv stations working we went about trying to set our sanyo dvd player to the tv. Once all the inputs were in the right terminals and all...
Bad cable probably. As you are going through direct connection ie AV I would be looking at either the cable or more probably are you connect to the correct AV video out put from the DVD?
Jul 26, 2008 | Televison & Video
Sanyo tv
cable bos is a scientific atlanta
Mar 18, 2007 | Sanyo PDP-42H2A 42 in. Plasma Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
