Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 46 inch regza1080p wont turn on. it clicks,yellow blinking light at front
Fast clicks when I try to turn it on, yellow light comes on and blinks then goes away.
    Top Expert:
  • Toshiba Master
  • 74,459 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 29, 2014
SOURCE: Toshiba 42HPX95 wont turn on
I am having the exact same problem with my Toshiba 42HP95. From the information that I have been able to glean from the internet, it looks to be some sort of problem with the power supply or some other component of the power circuit. I am giving up and getting service
Posted on Jan 16, 2008
SOURCE: yellow light blinking - blank screen - won't turn on
The problem is with the signal board. Basically, it is not allowing the power signal to go from the on button from the set or the remote to the TV. I am having the exact same problem with my 42" LCD Regza. Currently, if you are under warranty, Toshiba does not have these in stock. They will not have them available to send until early January. My TV has been at the repair shop since December 4th. I am very upset as I won't be able to watch the bowl games in HD. If your set is still under warranty then call Toshiba help line at 800-575-5469. You will need the model number of yout TV that is listed on the front of the owner's manual. They are:
27HL67
32HL67
32HL67U
37HL67
42HL67
The first number will be the giveaway as to which model you have. It is the size of your set. They will ask you to try a hard reset. (Hold pwer button down for 5 seconds until you see the yellow light go solid and go off.) This will most likely not work. If it does, you are lucky. I found that if you unplug the TV for an extened period of time, ie overnight, ity may come back on. It will eventually give out completely though. Better to get the problem addressed with the manufacturer. If you are not under warranty then I do not know what to tell you. Right now I am searching the internet to see if I can find this part to maybe purchase myself. Only if it is not too costly. If I find anything I will post here for all. If you have any questions, feel free to email me a wkjtx@hotmail.com and I might be able to give you more details on your problem. Good Luck.
WJ
Posted on Dec 17, 2008
  • 5 Answers
SOURCE: Blinking RED power Light 42hp95 Toshiba
I turned the 42HP95 TV off one night and it didn't come back on. Had the red LED flashing etc. Found the solution posted by CheapTech: http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back but didn't take it seriously because these things never work, others were mocking the answer blah blah. Well, just before kicking the damn thing to the curb, I grabbed a screwdriver, took off the back cover, unplugged the little do-hicky sugested in the Solution, and the idiot box came right back on. Go figure. Been working ever since. SO, you might want to try this before busting out the electrical schematics and dropping $$ on repair. Cheers.
Posted on Feb 20, 2009
  • 8457 Answers
SOURCE: TOSHIBA MODEL #42HP95-BLINKING RED POWER LIGHT WONT STOP
Ur power inverter board is dead.
U need a new board.
Posted on Sep 07, 2009
SOURCE: Our Toshiba Regza won't turn on.
Down load this firmware file p/n 2007SEN069 from this address http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=26hl67. The instructions are here also. Un zip to a blank sd card. I'm not sure if the set will boot to the card or not.
I finally got the tv to boot by constantly plugging in the a/c power and unplugging the power until it filally booted and was able to turn the set on.
Remove the sd slot cover from the lower right rear of the set, and insert the sd card with the unzipped firmware. Monitor the screen and follow instructions. Do not remove the card until the set powers off.
This fixed mine, hope others benefit from this repair.
David
Posted on Jun 28, 2010
2006 mitsubishi tv WD 62627. Tv wont come on i hear a click when I hit the power button. Blinks green on timer for about 60 sec then goes to solid yellow light on status. Error code 46.blew fan out.
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get an idea about the fault circuit section inside it. http://electronicshelponline.blogspot.com/ Visit the site linked here to know more details about the blinking codes.
Feb 18, 2017 | Mitsubishi Televison & Video
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
Sharp tv 70 inch wont turn on blinking 5 times fast 2 times slow
Which model do you have because the blink code differs from model to model. Did you try a hard reset? Meaning, unplug the unit, wait a minute or two, then holding the power switch down, plug the unit back in while still holding the power switch down. When it comes back on, release the button.
Jul 14, 2015 | Sharp Televison & Video
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
Just replaced the bulb on my toshiba 46 inch dlp..the tv stays on about 5 minutes and then turns off with the red and green light blinking...can you please help me?
Hi lilgyps
To answer your question;
The official release date was the 1of june 2009
And sometimes at the back you may even have the month that yours was manufactured.
Jan 23, 2010 | Toshiba 46H84 46" Rear Projection...
Wont turn on
Replace both of your STK ics 392-560s or 570s they maybe 392-110s if so use 392-180s call electronixs for parts 1-800-223-3205
Dec 12, 2008 | Toshiba 50HM66 52" Television
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
224 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
