Question about GE Spacemaker 75300 Shelf System
How do you turn the radio on
I received this system 2nd hand. I don't know how to find radio stations to listen to. Please help.
I am trying to re tune to my local radio station radio Merseyside on dab but it says station not available or goes to another station ?
Have you checked the frequency of that Station?
Also check your aerial.
I have also found this:
Listeners to DAB digital radio in the Merseyside area will need to retune on Wednesday 20th April following a frequency change that will affect local radio stations.
The local DAB multiplex carrying BBC Merseyside, Radio City 1-3 and Capital Liverpool among others will be moving to a new frequency in order to allow better reception over a wider area. The current frequency will be turned off late on Tuesday 19th April. The new frequency will go live from 6am on Wednesday 20th April, after which listeners will need to rescan their DAB radios in order to continue listening.
May 26, 2016 | Audio Players & Recorders
I am using a Denon internet radio on LAN (pirelli modem), works fine, but I cannot receive BBC. BBC on the PC works fine. Could that be a router problem? Any ports or adjustments I have to consider? If so,...
I have the same problems with my Pirelli modem in Austria (A1) trying to play BBC radio stations. I connected my Denon CEOL RCD-N7 to a different network (SilverServer in Austria) and it played the BBC radio stations swimmingly (not sure what modem was used btw)... I have another internet radio at home (Reciva based) and surprisingly, that one plays the BBC stations fine using the WMA streams.
I do have a workaround now for the Denon system: I have added the following URLs (AAC streams) to "My Added Stations" on RadioDenon.com and they work like a charm:
http://www.bbc.co.uk/radio/listen/live/r1_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r2_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r3_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4x_aaclca.pls
Any suggestions as to what the issue might be with the Pirelli modem are welcome!
-- Hope this helps.
Jan 29, 2013 | Denon Audio Players & Recorders
Motevo gtv x3 touchscreen: I don't know how to set radio stations. Once I find a radio station I try to store it, but I don't have a clue how. Can someone explain it to me or tell me where I c
I just bought a used honda city that has this Motevo GTV-x3+ installed. I was successful in storing the channel using the remote. After I go into the radio section, I touch the "Scan" button on screen and once it pauses on a channel I like, I touch the "Scan" button again. This stops the tuner from moving on to the next channel. Next, using the remote I long press a number for example 1 and the channel is stored in the list on position 1.
Oct 22, 2012 | Motevo GTV-X3 - 6.2" Touchscreen...
Suddenly yesterday this equipment stopped producing any sound. Not even on the TUNER option. Usually it receives sound from a satellite receiver also. Now it is mute. It is connected to a pair of JBL H-F...
Hi,sorry for my dumb question...is your receiver 's "MUTE" switch is ON or OFF ? because your description relates directly to this feature..if it is on make sure you switch it OFF but before doing this pls make the volume minumum..
if problem continues pls let me know for further help..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 18, 2011 | Audio Players & Recorders
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
I have an older onkyo integra (TX-870) which pop when I change stations, then no sound. Need to turn off and begin again. Can this be fixed or should I purchase a new 2 channel sys?
Hi, It sounds like you are listening F.M. radio and the F.M. muting button is engaged ( as well it should be-otherwise you will have static between the stations ) sometimes there is almost a "THUMP" sound when you switch stations-this is caused by the receivers P.L.L. circuitry losing then locking in on stations, if you do not lower the system volume you will amost assuredly cause an overload of your final drivers, that's why it will come back on when turned off-it has reset. Turning off fm muting will get rid of the "POPPING" noise-it will however leave you with unbearable static which in turn should cause you to lower volume momentarily eliminating the need to constantly turn off the receiver. Thank for asking FixYa, I hope this helps, let me know how I did or if I can be of more assistance, good luck Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
I may not be in right area for my question, and perhaps you could redirect me. For years we've listened to our local station 104.9, and now the transmission to that station has totally failed, and another...
Improve the aerial on the device you are listening to it on, or move it slightly if it is portable. You can also listen to it online.
If that doesn't fix it, you can complain to your local radio telecommunication authority as the new station may be a pirate and not registered.
You can also phone the 104.9 and tell them.
local station 104 9 Google Search
Mar 05, 2018 | Delphi Roady XT XM Radio Receiver
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
In my settings there is no fm transmitter selection available
As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
Jun 12, 2010 | Sirius Sportster 5 Satellite Radio...
Connecting outdoor speakers thru satellite box
go audio out of you sat box into a 2 channel amp or into your surround receiver if you have a 2nd zone, if the surround receiver is 7.1 u can most likely hook them up to the surround back and then change the setting to be a 2nd zone instead of surr back hope this helps.
Phtba
Mar 15, 2010 | Audio Players & Recorders
GE Spacemaker 75300 Shelf System Logo
37 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Jim Goldsmith
Jim Goldsmith
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
