HP Laserjet 4250n isn't working, IP Address is 0.0.0.0. How do I fix this?
One day our company printer wasn't working, the guys left it go for a week, and now i got put in charge of the problem. Any Ideas?
  • Jacqlyn Ellison
    Jacqlyn Ellison Mar 29, 2014
    Okay, So I figured out that the settings that I put into the printer restes itself. Now how do I fix that?
4 Suggested Answers
NotAsUsual
  • 43 Answers
SOURCE: hp laserjet 4250n paper jam in 13.01.00
According to the manual: "A 13.01.00 error message indicates that the media did not arrive at the pre-feed sensor (PS102) within the specified time." That usually means that the rollers fail to pickup the paper from Tray 2. Usually, cleaning the paper feed roller in the 500 sheet tray should fix this. While blowing out dust, you may have coated this roller with paper dust. A quick way to double check this is to power cycle the printer & try to print from Tray 1, the MP feeder tray (unless Tray1 has rarely or never been used...it might be a little tempermental as well). Regardless, this error is very common & is usually fixed by cleaning. Depending on usage, this roller is considered a customer replacable item (Part # RM1-0037-000CN) with a life expectancy of more than 200,000 pages. There are 3 of that type roller in the printer, but the one in the tray is usually the 1st one to fail. Hope this helps!
Posted on Jun 02, 2008
  • 109 Answers
SOURCE: Sir, We have a hp laserjet 4250n printer since
Replace the fuser unit (they last about 75K pages in my experience)
1. Power down the printer and unplug it
2. Remove the fuser from the back side of the printer
3. Replace the fuser unit with a new one
4. Turn the printer back on
Posted on Dec 24, 2009
Geekman
  • 32281 Answers
SOURCE: what is the default ip
There is no default IP address on HP printers with Jetdirect print server card.
You set the IP address in the printer's network settings. The IP address need to be set to match your network's address range.
To configure the HP network printer to work on your network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Posted on Dec 14, 2010
Why Does my Printer not save IP Address
if no network cable is connected then it will always show as 0.0.0.0 this is because the network connection is not activated without a network cable
Mar 31, 2014 | HP LaserJet 4250n Printer
Geting erro of 59.00 in 4250 printer
hi
HP LaserJet 4250n Printer - (Q5401A)
replace the fan --- erro 59.00 is failed fan.
on right or left of printer
Fan RK2-0278-000CN In stock
Cooling fan - Located on left side of printer (FN101)
RoHS: Modified
93.60 0.00 93.60 RK2-0280-000CN In stock
Cooling fan - Located on right side of printer - Provides air to the print cartridge area (FN103)
RoHS: Modified
Aug 01, 2011 | HP LaserJet 4250n Printer
Not able to change the default gateway. It just takes what ever the IP address is
Are you using DHCP to obtain the IP address? If so, typically the gateway will be automatically assigned, and if the DHCP server does not have a gateway programmed in the printer will default to it's own address. Change the IP setup to manual and you will be able to put in any address you want for the gateway.
Jul 12, 2011 | HP LaserJet 4250n Printer
What is the default ip address of the printer hp laserjet 4250n?
Dec 14, 2010 | HP LaserJet 4250n Printer
My network printer not taking ipadress as i have provided static ip through laptop.is there any settings in printer to add ip address . thanks , kalyan
First, make sure you have plugged in a network cable CAT5 or CAT6 into the printer's network card (if you don't have one, then you can't use it as a network printer). Also, the network cable should go to a switch, hub or router.
Second, the IP address needs to be set on the printer, not through laptop. You should browse to the menus of the printer, until you find a menu Network, under this menu you should have TCP/IP sub-menu where you need to set the IP address, also there must be a Subnet Mask sub-menu and a Gateway sub-menu. This two options should be set up as well.
Nov 23, 2010 | HP LaserJet 4250n Printer
Hp leserjet 4250n network ip change solushion
Print out the current configuration of the printer, Press the Tick button, navigate to Information, press the tick button, navigate to Print Configuration, press tick button.
On the printout find the current IP address. Open a web browser and type the IP address into the address bar, press enter.
The printer setup will be loaded into the web brower. Navigate to the network configuration so you can see the IP, gateway and subnet IP addresses.
You can now change these but once you have your browser dispay of the printer will disappear.
Type the new IP address into the web browsers address bar and you should get the new configuration displayed.
Sep 03, 2010 | HP LaserJet 4250n Printer
Need to move networked HP 4250 n from one IP scope to another
Yes. On the front panel menu, go to the I/O submenu and under that submenu you'll want the embedded jetdirect menu. This is where the network settings can be configured.
Feb 24, 2010 | HP LaserJet 4250n Printer
Printing Problem
GO ON LINE AND TYPE INTHE FOLLOWING INFORMATION; EXAMPLE:
HP LASERJET 4250N PRINTER ERROR MESSAGE KERNEL
ENTER
"" "" "" ILLEGALOPERTORSEQUENCE
ENTER
HP LASERJET 4250N ENDCHAR ERROR
ENTER
HP LASERJET 4250N PRINTER POSITION 24 ERROR
ENTER
HP LASERJET 4250N ERROR MESSAGE [ CODE # ]
ENTER
ROD THE CANDYMANGANDY
Dec 20, 2008 | HP LaserJet 4250n Printer
HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
Aug 18, 2008 | HP LaserJet P2015n Printer
27 people viewed this question
jasbo
jasbo
