Question about Samsung Clp620nd - Clp-620nd Color Laser Printer - Laser Printer - Sasclp620nd
Install new cassette pickup roller Samsung CLP 620 ND
How to replace cassette pickup roller
antiochpc
  • 1314 Answers
SOURCE: Replacement fuser unit for Samsung CLP-510
The part number you need is JC96-03239C-N
You may order it through this website; you'll need to call them for pricing information. They are a reputable company that I use to obtain parts.
Thanks and please give this solution a thumbs up rating, solving your problem.
Posted on Apr 26, 2009
  • 8 Answers
SOURCE: Samsung CLP 500 Error message 'Replace transfer roller'
You need to enter the hidden engineer menu: turn the printer off then turn on again whilst holding down the enter key on the control panel. It should say something like EDC menu on the display and you can scroll through several menus to find the one about resetting counters. Be careful not to play with other options as you can screw the printer up if you don't know what you're doing!
Posted on May 06, 2009
SOURCE: Samsung CLP-300 has grinding rollers
mine is the same way, to solve this I elevated the bottum by 2 inches, then i kept it off, also i blow a fan on it while running. also, you need to clean the filter (the gray "L" inside) black dust should come out. lastly, mine actually broke because it overheated. matt
Posted on Jun 05, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: samsung clp 315 printer shows "replace/install
Hi there your printer wast toner drum is full. So just remove that and make empty the drum & then refill the toner box. now use. Thanks.
Posted on Dec 22, 2010
  • 111 Answers
SOURCE: Samsung SCX-4521F pickup roller is
the machine need to be diassembled and the part is availebl from samsung as a new part only!
You can try to find a free computer service station at your home place perhaps they have a used roller and are able to replace it for an smal amount.
Posted on Apr 18, 2011
The paper keeps jamming in our Samsung laser printer 660 nd. We bought heavier paper for a laser printer but it still jams.
The ideal paper is around 80 GSM (gm2) if you are having problems with a BRAND NEW REAM of standard copy paper then your printer will need service.
paper that is thicker/heavier than this can actually cause more jams and problems and show worn out rollers earlier
These printers only tend to jam at the entry (pickup) near the base of the printer or in the fuser unit (hot area near the top)
if you are getting jams in multi page documents, have a look at which area the most crumpled piece of paper is in before you try and remove it.
the pick up rollers and separation pads are relatively cheap but the fuser units can be a bit pricey.
CLP 660ND CLP 660ND XAA Support SAMSUNG Canada
Sep 29, 2014 | Samsung CLP-660ND - - colour - laser -...
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
How to reset samsung clp 620nd
You can reset the printer settings to factory defaults using web management console .http://printeripaddress,default username is "admin" and password is"sec00000".
Oct 30, 2012 | Samsung CLP620ND Colour Laser Duplex...
The samsung ml 2250 printer doesnt pick up the paper out of the paper cassette. It works someteiimes but mainly the paper is not picked up at all and you hear the noise like it wants to pick it up but cant...
Hi there,Don't think its the clutch. I would rather say its more a problem of the paper not getting pushed up against the pickup rollers so you could try stretching the spring a bit and see if it helps.. What you also could try is removing the tray and bypass the paper sensor and see if when you print the pickup roller does turn.
Regards
Jul 28, 2011 | Samsung (ML2250S3XAA) Paper Cassette for...
Samsung CLP-300 printer not printing, the paper tray will not pick up the paper.
Often the rubber pickup roller is either worn or dirty. It is located just above the paper tray. Use a damp cloth and try to cleaning it, sometimes that helps. Otherwise you will need to replace the roller.
Jun 16, 2011 | Samsung CLP 300 Laser Printer
We have an samsung clp 300 printer. problem is it makes a grinding sound with the gears plus paper feed takes paper put then stops half way
The grinding sound is usually caused when the toner cartridge gear is slipping with the one in the imaging unit. To troubleshoot, remove the toner cartridge and turn the gear by hand and check for binding. It should turn freely, if it doesn't there nothing you can do but to replace it when it gets empty. Another cause of the gear slipping, is that sometimes the cartridge contacts force it out of the socket so it does not seat properly. To fix, try pressing on the cartridge contacts with the back end of a pen a few times to see if that will free up the contacts.
If your printer get paper jams when it starts to pull the paper from the cassette. This is caused by a dirty paper pickup roller. If it is not too worn out, you can fix this by using a damp cloth and clean the roller. Hope this helps you.
Jan 31, 2011 | Samsung CLP 300 Laser Printer
My Samsung CLP-315 Laser Printer will print about a half page and then jam...everytime!
does the jam came out to the exit and stuck there or it jam in the printer or before the pickup?
if it got jam at the exit. the exit sensor is faulty it got to replace.
if it got jam in the printer. the transfer belt or fuser is faulty. both got to replace
if it got jam before pickup. pickup roller got to replace.
May 09, 2010 | Samsung CLP 315 Laser Printer
Washed out printing both in colour and text
check on your pc smart panel that is install for any error detect for your printer.
follow the the error to get it check is much easier.
hold and press on the button of the printer for 5 sec to check on the supplier infor. that tells you the waer and tear item to be replace.
advice is to replace the toner block (OPC) image drum
if you do not have a smart panel install. you may go to www.samsung.com -> support and download the smart panel program.
http://www.samsung.com/sg/support/download/supportDown.do?group=pcperipheralsprinter&type=printermultifunction&subtype=colourlaserprinter&model_nm=CLP-300&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010200&acc_ia_fl=&disp_nm=CLP-300&model_cd=&menu=download
select the correct version with your OS.
1. OPC image drum - 25K +/- 2. transfer belt 25K +/- 3. transfer roller 20K +/- 4. pickup roller 20K +/- 5. Fuser 25K +/-
Apr 05, 2010 | Samsung CLP 300 Laser Printer
Hi, I've had this Samsung color laserjet (CLP-510) for a while now - found no reason to upgrade cause it's a great work horse. Now however from job to job it grabs an extra sheet of paper or two, and then...
It seems more likily that your pickup roller and separation pad has already worn out.
You may want to try pull out your paper tray and remove the pickup roller. Adjust the pickup roller and the paper tray separation pad may help.
next you may want to test with a single sheets of paper to see if the paper jam at the back of the printer near exit. If it does, you will need to replace your fuser too.
you can check the supplier info by going to menu -> system setup -> report -> supplier infor -> print -> yes.
Information below for item that is wear and tear.
1. Fuser - 25K +/-
2. Transfer roller 20K +/-
3. Transfer Belt 25K +/-
4. Pickup roller 20K +/-
5. Image Drum 25K +/-
hope this help :)
SamsuTech
Feb 20, 2010 | Samsung CLP-510 Laser Printer
Samsung Clp620nd - Clp-620nd Color Laser Printer - Laser Printer - Sasclp620nd Logo
141 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
