Question about Electrical Supplies
Is there a daewoo forklift g25p-3 wiring schematic pdf file i can download
My starter kicks on with the key in on position and does not disengage after lift starts
  • 7 more comments
  • michael thompson
    michael thompson Mar 28, 2014
    but would that make the starter kick without the key in start position?
  • cals-studio Mar 28, 2014
    i was refering to starter worm gear getting jammed , but it sounds more like faulty ignition barrel , to attempt to start in on position , assuming you don't mean start possition .
    could also be starter soliniod itself , not the one on starter motor
    when you turn the key to start , this should actuaute the starter soliniod , which then sends the power to starter motor . if starter motor is staying on starting and gear is still engaged , then starter soliniod is sticking on it's contacts.
    but this can happen also if starter motor gear actuater gets stuck also .
    hope this helps...
    i managed to down load daewoo nubira manual which had everything including wiring schematics
  • michael thompson
    where did you find the manual download and would it have info on my g25p-3 forklift?
  • cals-studio Mar 29, 2014
    www.o2epc.com try here also plenty of manuals
    Scholar:
  • 128 Answers
Replace the starter motor , sounds like soliniod sticking or worm gear sticking .
Posted on Mar 28, 2014
  • michael thompson
My r6 doesnt turn fully on disengage the headlight assembly everything turns on like normal.but then it wont turn over. I just get this buzzing sound from high and low beam relays. wiring looks fine
Hi, Sappo and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r6-forum.com/forums/46-general-discussions/6691-2000-r6-wont-start-wut-could-problem.html
http://www.r6messagenet.com/forums/welcome-center/161248-please-help-bike-wont-start-turn-over.html
2001 Yamaha R6 won start in Sportbikes Page 1
http://martin.lipinsky.cz/r6/files/LIT-11616-21-61.pdf
Apr 28, 2016 | Motorcycles
Car wont start
Best Manuals
for the easy solution download the pdf file
Jan 20, 2016 | Cars & Trucks
Starter relay will not disengage starter new ignition switch new starter when ignition is turned to the on position motor starts relay is removed starter disengages relay socket remains "hot"
the wires at the ignition switch are wrong
the power to the relay should only be hot when the key is in the start position and not the run position
Oct 01, 2015 | 2004 Mazda Tribute
No power to starter
Hi, Anonymous and the usual suspects are:
6. Faulty kick stand or clutch pull in switch/sensor.
Star 1100 Starting Problem electrical HELP
Starting Problem on vstar classic
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Apr 08, 2014 | Yamaha V Star 1100 Classic Motorcycles
Need forklift wiring diagraM for daewoo g25p-3
http://www.tradebit.com/tagworld.php/tradbit. This is download you will need to purchase it
Mar 28, 2014 | Cars & Trucks
I have a Bobcat CT445 SST that won't start, turns over but no start. All safety switches checked good. Found that the fuel shutoff solenoid is not disengaging when the key is turned on. Replace solenoid...
First off and 12 volt battery should have 14.4 volts when charged. A dead battery is about 12 volts and many actuators, solenoids, starters etc won't engage at such a low voltage. Secondly think of a test to narrow the problem to No Spark, or No Fuel. I just read a site that says they are known for sticky fuel solenoids... perhaps tap it with a screwdriver handle or replace it.
Nov 02, 2013 | Toys
Diamo scooter kick starts electric starter not wiring
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Scooter Troubleshooting Scooter won start All about Scooters
http://www.linnbenton.edu/auto/perform/no_start.html
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial http://scmotorized.com/image/data/pdf/scooter-repair-manuals/Retro-150--Parts-Catalog-V.12.07.pdf
Diamo Retro 150 2007
Sep 24, 2013 | 2007 Diamo Retro 150
Baja sc50-2 scooter
Hi, Benny and the usual suspects are:
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Startup Troubleshooting Starting Your Scooter 1 7
Scooter won start
Baja Panterra 50 90cc PDF Service Manual Downloads on 4Strokes com Forums
http://www.bajamotorsports.com/system/documents/63_OWNERS_MANUAL_-_SC50_-_Sun_City_50cc_Scooter_Owners_Manual_VIN_prefix_LAWA_.pdf
Feb 13, 2012 | Bajaj Caliber 115 Motorcycles
I need a wiring diagram for the starter on my 311B caterpillar eskavater
Attached is a link to a PDF file containing the wiring schematic for the entire electrical system of the 311B excavator. I could not find one isolating the schematic for the starting system, but this should help you (though it may take a little bit of time to sort through the diagram--sorry about that).
Please note that I am hosting this file myself and the link will only be valid for 30 days.
You can find the schematic here: https://files.me.com/sgoldberg08/thbvvb
If you find this solution at all helpful, please leave a positive rating!
Jul 01, 2011 | Computers & Internet
Electrical Supplies Logo
99 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
