Question about Canon imageRUNNER 5000 Copier
E000880-0004 Receiving the error when powering on the machine. It states to turn the machine off and back on again. We have tried this as well as unplugging it and plugging it back in. No further information is provided on the screen. Printer is Canon ImageRunner C5035.
  • 66 Answers
SOURCE: Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Posted on Apr 23, 2009
SOURCE: Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Posted on May 15, 2009
komguy
  • 2306 Answers
SOURCE: printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Posted on Jun 23, 2009
  • 57 Answers
SOURCE: Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Posted on Sep 03, 2009
  • 284 Answers
SOURCE: My Canon MP980 is showing Printer Error code 6000....
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
Posted on May 27, 2010
Error code E000002
That is the error code for a power supply failure or the printer not receiving enough power to heat the fusilier to print. This can be due to an power outage or not enough electricity flowing into the machine.
If the machine is receiving full power, you'll need to get rid this error through entering service mode.
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
NOTE: from this point forward you'll be in service mode which has a 60 operational second window. After 60 seconds it will exit out of this mode and you'll have to start over.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
The printer should restart and be working normally.
Feb 21, 2016 | Office Equipment & Supplies
Faxing problem with HP Office Jet 7130 all-in-one
hi-
chances are you need to change the setting on you hp printer, i mean the fax settings for it and by the way have you tried reseating or unplugging the wire that connects from the wall to your hp office jet? try to unplug and replug it then try sending another fax, update me for any unusualities, thanks!!
May 20, 2008 | HP OfficeJet 7130C All-In-One InkJet...
What e59 means
Hello Ninemi,
I see that you are receiving an E59 on your Frigidaire Affinity washer. E59 states that "No Tacho" Signal for 3 seconds. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the washer is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back to the washer and try to restart it. If you are still receiving an E59 error code, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 22, 2014 | Frigidaire Affinity FAFW3511K Washer
Whenever i turn my Canon BJC85 portable printer on, the green power light and yellow error light flash and 8 beeps are heard. The printer will not function in this state & the ink cartridge carriage is...
Hello, you can read the error codes here:
http://www.uktsupport.co.uk/canon/bj/bjc85.htm
it seems to be a temperature error and cannon suggest that you replace the print head.
Removing the Cartridge ( Print Head )
1. Make sure that the printer is turned on, then open the cartridge cover.
2. Press the CARTRIDGE button to move the cartridge to the center.
3. Remove the BJ cartridge.
Let the machine be without the cartridge, close it, turn it off and back on, is the error still there? then redo the above and attach the cartridge to the machine, if the error is still there, try another cartridge if possible if the problem still remains, turn the machine off for atleast 15 minutes / unplug, then try again.
Jul 08, 2011 | Office Equipment & Supplies
I have a Rocoh Fax 1700L fax machine and its not receiving faxes. We can send faxes but not receive them.
The technical manual is stating that the problem is with the left lock lever make sure that the door is shut correctly power down then back on again. If the problem comes back I think it maybe the laser unit then and it will need replacing. Also could check here the Fax 1700 Service (RAR zip format)
Keep us updated.
Feb 09, 2011 | Ricoh Office Equipment & Supplies
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
solution:
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
Automatically Shutting Down then unable to turn back on
Sounds like overheating, if the machine just cuts off its either power fault or overheat and the machine will hit a certain temp about 90C for a period and cut out to prevent severe component damage .
you can try cleaning again, the thing is if its been running at high degrees C it may need fresh arctic silver on the CPU which thankfully is a pretty robust one in that machine.
hope this helps, let me know if you need further help
Nov 07, 2008 | Fujitsu Siemens Lifebook N5010 Notebook
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Canon imageRUNNER 5000 Copier Logo
453 people viewed this question
old marine
old marine
