Question about Baby Gear
Can't fit back wheels
Trouble assembling the back wheels
  • Baby Gear Master
  • 1,629 Answers
Hi Toni
We'd need to know the make and model of the product to be able to assist.
Posted on Apr 06, 2014
What part does the wheel bearing assembly sit attach too. big round steel connected to the strut
who fitted it, needs to be done by a proper mechanic or you could lose a wheel whilst driving. After it was fitted the retaining nut should have ben tightened fully home so that it could not have been tightened any more, then the nut should have ben undone/loosened slightly and torqued to the appropriate value. Then a split pin, if there is provision for one, should be fitted.
If you do not have proper tools take it to a mechanic to do the remedial work, it could be hazardous to yourself and family and also other road users.
Good Luck
May 28, 2015 | 2001 Ford Windstar
P0321 and p0322 on a 02 passat
Trouble Code: P0321
Ignition/Distributor Engine Speed Input Circuit Range/Performance
Possible Causes:
Engine speed sensor has failed or is damaged.ECM has failed.Sensor wheel is damaged or doesn-t fit properly.Sensor wheel spacer isn-t seated properly.
Trouble Code: P0322
Ignition/Distributor Engine Input Circuit No Signal
Possible Causes:
Nov 18, 2012 | Volkswagen Cars & Trucks
The front wheel assembly seems to be 'inside out'..the teeth are on the inside therefore it does not fit over the hose, and will not stay on. How do you remove and turn the white plastic wheel
You will need to pry off the cap nut on the end of the shaft (which runs through the two wheel halves. The ONLY tool that will do this is a vice grip and a couple of beers. Also, swearing seems to help.
Clamp the vice grips on tight and rock it back and forth.
You will need to get a replacement cap nut from your local hardware.
You can purchase a complete, new front wheel assembly from Nelson for $12.35. Part number 1609714466.
http://www.lrnelson.com/replacement-parts/
Jun 06, 2012 | Nelson Sprinkler: Traveling Tractor
Wheels keep coming off
1 - Remove rear wheel
2 - Remove posi screw from bottom of rear wheel hub assembly
3 - Allow bottom block and spring to fall into palm of hand
4 - Push rear wheel lock bottom down through rear assembly to remove.
5 - Clean wheel lock button and locking plate to ensure free movement.
6 - Clean rear hub and locking button housing with dry cloth.
7 - Apply lubricant thinly in recess to allow free movement of button (dry Teflon spray is best - find it in the laundry aisle of larger supermarkets)
8 - Re-fitting is reverse procedure of removal instructions.
Nov 30, 2011 | Quinny ZAPP Stroller
Brush assembly won't spin
you must replace the pump thats what the belt is attached to
Dec 01, 2009 | Bissell 8910 ProHeat Clear View Upright...
HI,I have a Trooper 1998 3.l diesel,but I have a problem with the clutch,the car will not drive,exsept very slow,do I need to change?Where can I get somthing some tell me how I shall repair this problem
You need a new clutch fitted , most likely the friction plate will be the only part needed.
You have to take the gearbox out the way to do the job .
Aug 02, 2009 | 1998 Isuzu Trooper
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover Floormate wheel assembly
You must remove the top gray piece it has six tabs 2 in front, two in back and 2 on sides where the foot pedals are. Be very careful not to break them. Then you cn remove screwsa nd install the piece.
Oct 22, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
