Question about Synaptics PS/2 Port TouchPad
Gateway touchpad buttons don't work
Tochpad works, wheel works, buttons don't work
  • Bob Sloan May 27, 2014
    Hi LInda Koetter, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    What model is it, and what operating system.
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Internal tochpad wont work
You probably have the touchpad turned off. Some models will have a button at the top of the touchpad in the middle that toggles it on or off.
Some models you can tap twice in the upper left hand corner of the touchpad to toggle it on or off.
I've seen some models where the touchpad is toggled by keystrokes. You had to Press and Hold the ALT or FN function key then hit the key that toggles the touchpad. The correct key to hit had the icon of a finger pointing at a touchpad.
Click Start/Control Panel and check the Mouse or touchpad drivers to make sure the settings are ok. I would just set everything back to Default.
Maybe you need to reinstall the touchpad drivers if any of the above does not solve it.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad drivers.
Apr 30, 2012 | Acer TravelMate 2300 Notebook
Touchpad not workin at all
u can turn on or turn off the touchpad functionality of ur notebook..what must have happened is u would have turned off the touchpad of ur notebook by mistake & now u dont know how to turn it on....The key to turn on the touchpad can be different on different notebooks...so it would have been easier for me to provide u a resolution if u would have also mentioned the model of ur notebook... Generally there is a small button just beside the touchpad which is used to turn or off the tochpad, if the small button is amber in color then the touchpad is turned off & if its blue in color then touchpad is on...otherwise sometimes there is no button beside the touchpad & then there is a key combination to turn on or off the touchpad & it is Fn+F7....
try this out, it might work for u, if it works then let me know by rating this solution...
Jul 10, 2010 | Microsoft Windows Vista Home Premium with...
My touchpad has stoped working on my Acer Aspire 5732 Z
Sometimes it differs but you can try pressing FN and F7 together on your keyboard to see if that will enable the touchpad again.FN should be next to your left-ctrl on your laptop keyboard.
On other Acers, there's either a seperate button to enable the touchpad or a different Function key. See on your keyboard the function keys and choose the one that looks like a tochpad, with a pointing hand. Sometimes the icon on the key just looks like a mini-touch-pad.
May 28, 2010 | Acer Aspire 5720-6661 Notebook PC
Touchpad has stopped working, can you help?
Hi there don't worry. Its disable that's why not working. Please press FN+F7 and try. The symbol on your keyboard is below. Just press FN+ below mention symbol. Thanks.
Apr 07, 2010 | Acer Computers & Internet
Touch pad and mouse of acer aspire one notebook not functioning
hi
your touchpad may not be working due to following reasons.
  1. the touchpad driver not installed or corrupted. try reinstalling the driver.
  2. due to improper usage of the pad it is demaged.
  3. the button which activate the tochpad is off.
  4. the sensor got weak due to degradation with time.
call the customer care and they will replace it if its under warranty.
if you find the solution useful plz rate me carefully
Jul 02, 2009 | Acer Aspire 5101WLMi Notebook
Dell inspiron tochpad only works by holding down key on keyboard
It is likey the connection for the touchpad has come loose. As this connector is under the keyboard it would make sense that putting pressure on the keyboard causes it to work. If you are comfortable with removing a few screws, refer to the service manual on Dell's website on how to remove the keyboard. You will then see a ribbon cable connected to a plastic mechanism that secures the cable to the connection on the motherboard. Simply slide the top of the plastic mechanism forward or back to release tension on the ribbon cable, make sure the cable is straight and all the way forward, then slide the mechanism back into place and you should be okay. If you are not comfortable with removing anything, any computer repair shop should be able to do this for you relatively quickly.
Mar 19, 2009 | Dell F3534 Touchpad
Dell inspiron 1525 touchpad not working properly
You can try the following steps.
1. Turn laptop off.
2. Remove all external devices and disconnect AC adapter power cable from the system.
3. Remove the battery from the system.
4.Hold down the power button continuously for at least 5 seconds. Do not release the power button during this process.
5.Insert the battery back to the system.
6.Power the laptop back on.
Try using touchpad again.
Dec 29, 2008 | Dell Inspiron 1525 Laptop Jet Black
My tochpad an Card reader dont work
hi dear
try this site
http://www.driversdown.com/drivers/Acer-Aspire-4720-Notebook-Audio-Driver-v6.0.1.5413-Windows-Vista_72513.shtml
for new compatible driver
and for your touchpad just press ctrl+F7
oke, goodluck
cropp
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Top Synaptics Computers & Internet Experts
David Payne
David Payne
Are you a Synaptics Computer and Internet Expert? Answer questions, earn points and help others
