Question about Kenmore 22422 Top Load Washer
Unit will not drain or go into spin cycle - Kenmore 22422 Top Load Washer
2 Suggested Answers
SOURCE: 98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Posted on Dec 13, 2007
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
My Estate TAWS800JQ washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin. If knob is manually moved from drain cycle to rinse unit will agitate but not drain or...
Possible that the drain pipe is in a height where the water is struggling to lift.
If not id check for a block. I normally find a sock stuck in the drain hose which causes a problem similar to yours
Sep 24, 2017 | Estate TAWS800JQ Top Load Washer
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
My spin cycle on my maytag washing machine wont work. All else works fine but it wont drain or spin??? Please Help
check th elid switch to unit as it may have failed... it will stop the unit from going into a spin cycle and draining,,, give that a look and repost if you have anymore questions... good luck
Jan 09, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does 5d mean?
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters ofwater and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
8. Verify CCU operation by running a Diagnostic Test or any Cycle.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gets to the spin cycle and does not spin and drain
What is error code?
Does unit spin?
Does unit drain?
Does unit fill on all water settings?
Ie set to hot, warm, and cold and see if fills.
Jul 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Jan 24, 2009 | Maytag Performa PAV2200
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22422 Top Load Washer Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
