Ram trouble shooting cutsout on highway
Idles runs good in town
    Problem Solver:
  • 11 Answers
As far as i can tell your referring to a laptop and it seems you have a sloppy ram slot.
Posted on Mar 30, 2014
Possible causes or fixes
Hi Morley, does the bike misfire when it is about to stop?
Jul 16, 2016 | Yamaha Motorcycles
My 2004 dodge ram 1500 (Hemi) is overheating at idle but does fine on the highway, what could cause this?
According to anandtech.com, Tom said: "If this only happens at idle and your fans are operating and your coolant level is good, my suspicion is the thermostat. "
May 12, 2015 | 2004 Dodge Ram 1500
2000 malibu overheats on highway but not in town or when idling
check the tension of the fan belt. also make sure there is no debris on the radiator.
Aug 26, 2012 | Chevrolet Chevy Cars & Trucks
This is an intermittent problem that only occurs while highway driving. Most of my driving is in town. I can't see any leaks and am worried I may major transmission trouble. I hope you can help!! Thank You
Hi and welcome to FixYa!
During short trips transmission troubles are hardly noticeable. This can be noticed during highway runs. As a first course of action I strongly suggest that you replace the automatic transmission fluid. If the fluid is burnt the transmission tends to shift slow or simply just stuck in gear.
Once the transmission is replaced, a smooth run and shifting will be noticeable.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 28, 2011 | Chevrolet Lumina Cars & Trucks
Starts/stalls won't run until pedal tapped, 2 miles in town, 6 miles highway, then1000-1500 idle. shut down 9 hours, start/stall tap pedal runs return 6 mi. highway,2miles town same high idle. checked code...
Check your IAC motor (Idle Air Control) It could be sticking open.
Ps. Might be called Idle Speed Control motor it depends on the make and i forget what chevy calls theres.
Mar 11, 2010 | 2000 Chevrolet Malibu
99 dodge ram 1500 ac problem
recharge your system, it;s low on refrigerat, there is not enough liquid going into the evap to help maintain cooling, hence the speed of the compressor. install gauges to check pressures at idle, if not to spec , recharge. if it's low you have a leak to repair. also make sure your AC condenser is clear. GOOD LUCK. RDJRP
Jul 23, 2009 | 1998 Dodge Ram 1500 4WD
97 Virago 1100 will start and idle. No highway speed.
sounds like you have trash in your carbs u need to take bottoms off and run a piece of a wire wheel through the jets
Jun 22, 2009 | 1988 Yamaha XV 535 Virago DX
2004 Dodge Ram 3.7L Overheating
is the a/c running or not??
if it is check to be sure the auxiliary fan comes on when you turn the a/c on!!!
if thats ok then it's probably your fan clutch!!!
Jun 17, 2009 | 2004 Dodge Ram
5.3 L Missing and Rough Idle Intermittently
i have a 2001 chevy z-71 5.3L. I keep getting a random/multiple misfire code for cylinder 1 . I have replaced plugs, wires, coil pack(only on #1 cylinder)., and fuel pump. I still keep getting the cylinder 1 misfire code. I put truck on a scanner and watched the cylinders. # 1 misfires at idle but quickly stops misfiring at around 1000 rpms. you can here the engine miss at idle but truck runs great on road . anyone else ever had this problem?
May 05, 2009 | 1999 Chevrolet Silverado 1500
1998 Cavalier Quad 4 2.4l runs rich wont rev past 1500 rpm
can be a mass air flow, idle air flow ,or even a hole in the tube between the airbox and the throttlebody........any air leak will cause this to happen.make sure you have no vaccuume lines off either
Feb 01, 2009 | 1998 Chevrolet Cavalier
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
