Question about Boston Acoustics Duo-i Horizon Clock Radio
Display Panel Light is Out
In Brightness mode, I can see that the display is set to 20 (full bright), but it's dark as can be. Boston Acoustics CS suggested a 48-hour unplug to reset, which I did with no effect. The service center they provided in Syracuse notes that they've encountered this several times before -- quoted $150 - $160 (!) for repair, not including my shipping costs, which have to be another $25+. The unit is approx. 2.5 - 3 years old, and has not been mistreated or subject to any adverse conditions. I'm deeply torqued about this and feeling ripped off in the extreme. Is htere an easy fix I can do myself, or is the solution achieved through judicious application of a 10 lb. sledge?
    Problem Solver:
  • 8 Answers
Bull, the cap is leaking all over the board and has damaged the control microprocessor. Good luck fixing that yourself. No parts available, sorry.
Posted on Sep 12, 2014
3 Suggested Answers
SOURCE: Unit looses time
I just received a email from BA re this issue. They were amazingly prompt and friendly. Here is what I was advised to do:
"One thing to try is to let the radio recalibrate itself, this is done by leaving the unit completely unpowered and unplugged for 48 hours to let the cap drain and the unit will recalibrate itself"
Posted on Sep 16, 2010
issikiki
  • 563 Answers
SOURCE: My remote control stopped operating my Boston
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
Posted on Jan 26, 2010
Static after radio turned off
You are not alone. Memory cap will be bad on front display board(C137) 0.33F/5.5v. Replacing cap will not fix, micro damaged as well. Probably can't turn off except with remote and display brightness stuck as well. Board NLA.
Aug 15, 2014 | Boston Acoustics Duo-i Horizon Clock Radio
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
Hi My screen is really dark when inside night pictures. I have tried to increase brightness.But can't adjust. Can you help plse ?
The set may have an ambient light detector - if so then the set up options will allow you to vary the screen brightness - a simple check to find out if this could be the problem would be to display an image during the day then if possible close the blinda and make the room dark - alternatviley do the same at night then switch the room lights on and off and see if the brightness changes.
Mar 18, 2011 | Televison & Video
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
My screen is very dark ...cannot adjust brightness...
Hi, if it is very dark to the point that it is almost black and has no light at all then there is a part in the display needs to be replaced, it is called fl tube. if the screen is dark but still there is somewhat some light then try going into the power setting, your pc might be set for low brightness to reserve power, see if you can adjust there, otherwise your display may just be going bad... Best of Luck
Jan 30, 2011 | HP OmniBook 6100 Notebook
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
Dec 23, 2010 | ASUS VW193T Monitor
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Boston Acoustics Duo-i Horizon Clock Radio Logo
228 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
