Question about Kocaso M1052S 10.1" Android 4.0 Tablet PC
My charging doc has broken
I put charger in then pin inside tablet broke noone in a shop can fix it what do i do ??
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
The only way to repair would be to solder a new connector to the mainboard. It would be much cheaper to buy a new tablet.
Posted on Mar 28, 2014
Charger fot my acer tablet only goes half way in and wont charge
The pin inside the charger port might be broken.
Look in the hole where you put the USB (on the device) there should be a tiny flat tongue sitting in the middle, if it's bent and touching the inside of the hole, it will need repairing. It's a very common fault.
You might be able to temporarily fix it yourself by trying to straighten it with a tooth pick. It's supposed to slot inside the micro USB plug.
Oct 20, 2016 | Acer Tablets & eReaders
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
My irulu tablet wont charge
Check charger, cable and connectors. When you can borrow another charger try that one. If a new or good charger does not change the situation, and nothing is in the connector, the defect must be in the tablet, like a bent or broken pin in the connector, or a broken cable inside. An oxidised connection inside or just a defective main board, to mention some possible causes. As soon as the tablet needs to be opened, consult a tech, or start saving for a new tablet.
Apr 24, 2015 | Tablets & eReaders
I bought two irulu tablets but the both broke in the same exact spot, in the charging port. the pin broke out and i cant charge them now. Is this a flaw with all irulu tablets or just the two I bought
I would definitely follow your friends advice. If they are under warranty, you should be able to get them fixed. If the battery can come out of the tablet, you can use a universal charger to charge the batter, but I am assuming it doesn't.
If you know how to solder, then you could replace the port yourself, but this is risky, so getting pro help is the best bet.
Feb 14, 2015 | Tablets & eReaders
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Charger
If the end of the charger broke off inside your nabi, it will be difficult, but you can get it out. Ideally you still have the broken piece. Superglue the end, put it back in and let it set, then pull it out quickly. If you don't have the rest of the broken piece, you can use something like a toothpick or a cotton swab with the cotton tip removed. Check out YouTube for videos on this. If your charging cord just fell apart and nothing is broken inside your nabi, just buy a universal charging cord. Make sure the tip matches the one you broke. Amazon is a good place for finding these. It will still charge your device.
Apr 16, 2014 | Nabi 2
PLT7223G power pin broken
Try charging it with the USB cable from the computer. It could be your charger pin is faulty. This happens from frequent in and out charging. The pins on the charger tip get worn out. If it charges with the USB cable then get a new charger.Charging from the computer is slower but it works.
Mar 03, 2014 | Proscan PLT7223G-K 7in Android 4GB Tablet...
The charger is broken and i need another charger also the pieces of the charger is stuck where you are suppose to put the charger
You can charge your tablet through the USB port on your desktop computer. Just plug it in with the USB cable that came with your unit. It's slower charging but who cares?
Those pins are delicate. Be careful when inserting and removing.
The USB is designed to power on first and then the data is transferred.
Forget about taking it to a repair shop. The charges will be more than the tablet is worth and it's not likely they will have the part.
Dec 30, 2013 | Proscan 10.1-Inch Internet Tablet,...
How can i fix a broken charger port pin on archos 7 home tablet
Depending on WHEN your tablet was purchased, you can send it back to Archos to be repaired. (via their website http://www.archos.com/support/). I have broken the pin off in mine TWICE since I got it last November and both times I sent it back to Archos to fix free of charge. They paid for shipping and repaired it for free even though it was MY FAULT! so far there were no questions asked! I have been very pleased with their customer service (even tho i have never talked to a real person they have handled the issue and I am extremely happy). there are 2 issies w/returning it however, 1. you LOSE ALL YORU DATA. they wipe it out. I tried doing a back up and then reloading it to my tablet when i got it back but haven't been able to figure out how to get it back on. 2. You will be w/out your tablet for about a month! :( Good luck!!!!!
Jun 23, 2012 | Archos 7 Home Tablet Tablet Android 8 GB 7...
Kocaso M1052S 10.1" Android 4.0 Tablet PC Logo
62 people viewed this question
Top Kocaso Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
David Payne
David Payne
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
