Question about Janome Sewing Machines
Oil my machine
Where to put the sewing machine oil
  • 72 Answers
This really depends on the model of machine you have. Most new machines are self oiling, but some still require a drop of oil in the bobbin case. Your sewing machine manual should include a oiling diagram if your machine requires that the user oil their machine. You should be able to download a manual for your machine from the Janome website, even the retired models are there.
Chris
Posted on Mar 28, 2014
  • 1116 Answers
SOURCE: do i need to oil my baby lock sewing machine?? Quiter's choice.
I cannot find a manual for this machine except at sew4less.com and the price is $14.95.
Contact Babylock to see if they will provide you with a download of the manual - http://www.babylock.com/contact-us/index.asp
If this is a mechanical machine, use sewing machine oil and the shuttle may be the only place it will need to be oil.
Posted on Apr 30, 2010
  • 1116 Answers
SOURCE: should I oil my Elna 3005 sewing machine?
Many of the new models do not require oiling.
Check the maintenace section of the manual for cleaning the shuttle area. Sometimes lint can build up and cause the machine to get noisy.
If it has been over a year since the machine was serviced, it may be time for a proffesional tune-up.
Posted on Mar 13, 2010
  • 15 Answers
SOURCE: how to oil my sewing machine
Kenmore machines may have parts and manuals available on searspartsdirect.com -- have the correct model number usually a 3 digit a dot and the rest of the numbers (i.e., 158.xxxx or 385.xxxx1). You will see a list, and if you click on parts or attachments list and scroll down into the parts list, there should be a manual listed as either available or not.
As to the new machines, Euro-Pro or any other, if really cheap, then my personal feeling is that they are planned to not last for a long time -- which may account for the lack of oiling instructions in their manuals. The other possible reason 'may' be that like some Viking Husqvarna machines, the metal parts could be infused with oil and the heat from running them produces the oil needed as it runs. Somehow I doubt that could be the answer in an inexpensive machine. If a lot of the parts inside are plastic, then no oil is needed, and they will run until the plastic breaks, necessitating a trip to the repair shop.
Only use sewing machine oil which can be bought at any JoAnn's, Walmart, sew and vac, or sewing machine dealer. Never use household oil or the yellow/blue can of spray that is a water displacement solution which ultimately will gum up the works. You could use Tri-Flow Superior Lubricant.
Basic oiling procedure is to oil wherever metal parts meet (possible friction points) or slide past each other -- a drop or two usually. No grease needed on plastic gears. If you have an old machine with metal gears, then use sewing machine lube (grease) or Tri-Flow lube (can get it at a bicycle shop if no where else).
Posted on Nov 20, 2008
  • 300 Answers
SOURCE: How to oil Spartan 327k sewing machine
Use only sewing machine oil. Get an oiler with a long spout so you can reach far places, put a single drop of oil on every place that has metal moving on metal.
Posted on Feb 11, 2010
Sewtech1
  • 69 Answers
SOURCE: I have Husqvarna 2000 SL
Husqvarna Viking Service Maual
Posted on Oct 12, 2010
What type of oil to use on a empisal d 270 and how put the oil
sewing machine oil ( from a supermarket or sewing shop)and just a few drops in the oil holes
Jun 20, 2016 | Sewing Machines
Tip
Where to oil your sewing machine
The rule of thumb about oiling your sewing machine is to put one drop of oil (sewing machine oil only, please!) wherever one metal part moves against another. Do that, and you won't go wrong. You can also look for the oil ports -- small holes in metal gears and housings--I've posted a good photo at www.robbiesews.blogspot.com--where you put one drop of sewing machine oil. Don't use oil on the gears themselves--use sewing machine grease instead.
Oil ports and places where metal moves against metal can be found in three locations: on the top of the machine, under the cover; on the bottom of the machine; and behind the access door (or panel) on the left side of the machine head.
Here's a generic sketch:
Note: Please refer to your sewing machine manual to see if your machine is self-oiling. If it is, disregard this note--you do not oil those machines.
on Apr 13, 2010 | Rex RX-1804
Elna 6000 sewing machine
Consult your owner's manual and oil ONLY as instructed. Be sure to use good quality sewing machine oil as recommended (NOT old oil from your grandmother's sewing basket, 3-in-1 oil, WD40, or cooking oil).
Apr 07, 2014 | Sewing Machines
How often should it be oiled?
sewing machine oil is a very light oil so it does not hang around very long. if you are a heavy user of the machine it is best to oil it every month or so. if when it is stored for a long period it should be oil then too. there are one or 2 bits that need some light greasing too. some 3-1 oil is good for the job and do all the moving parts lightly and not too much oil as it will mark your clothes. hope this helps.
May 02, 2011 | Janome Jem Silver 662 Mechanical Sewing...
How to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Jul 24, 2010 | Kenmore Sewing Machines
Trying to figure out where to oil my old White 265 machine. the manual only talks about how to oil the bobbin shuttle.
Hi. The rule of thumb is to put one drop (just one drop, that's all it takes) of sewing machine oil wherever two pieces of metal move against each other. You can also look for the oil ports(see tip on where to look for oil ports and for a photo, see www.robbiesews.blogspot.com). Your machine may also have small oil holes in the sewing machine housing, so put one drop of sewing machine oil in each of those.
Please use only sewing machine oil to oil your machine.
Hope this helps!
Robbie
Apr 13, 2010 | Sewing Machines
Feb 09, 2010 | Sewing Machines
How to oil old featherweight
Hi! I love the old Singer sewing machines!! Do you have the user's manual for your machine? The manual has great diagrams showing where to put oil and grease. If you don't, check out http://www.221parts.com/
In the meantime, look for little holes, often with raised edges and put a drop of oil in each. Put a drop of oil wherever metal moves against metal. You'll need to oil inside the head, on the right-hand side where the motor is located (DON'T oil the motor--use grease instead), and also underneath.
Good luck and let me know how it goes.
Dec 15, 2009 | White Sewing 1300DE Sewing Machine
Where do i put the oil in for the machine
You can only oil the moving parts that you can see very lightly
Oct 18, 2009 | Singer 2950 Mechanical Sewing Machine
Sewing Machines Logo
174 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
