Question about Keurig B60 Coffee Maker
Water leakage in back
Im on my 3rd pot. Just returned the last one to BBB due to bottom water leakage. Got a 3rd one and this one is doing the same thing. Why and how do I fix it?
Buy one made in usa if you can find one...everything is made in china.its a dam shame,,,
Posted on Mar 29, 2014
Powerpoint dishwasher flashing E1 any solutions please
E1 is commonly know as a leakage error which occurs due to the excessive RPM of Washing Motor happened during Wash cycle due to water leakage. To start with check if there is a water leakage in hose connections, motor water seal leakage of sump assembly or water is leaked due to damages. Replace the connections of Hose if bad. Also check the point of damages and repair or replace the related parts.
Mar 07, 2012 | Hoover 24 in. HD98E Built-in Dishwasher
Wont fill with water. error E1 faucets is not opened. have water in mains.
Hi
E1 is a leakage error in your dishwasher; it is usually displayed either due to a clogged drain or due to water leakage in hose connections. If the drain pump assembly is not clogged then check the motor water seal leakage of sump assembly and also check the impeller of washing pump, if it is worn then replace the impeller. You can also make sure that the height of drain hose is not over 20". Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
It only makes 1/2 pot when I pour the water in after sitting over night some times it takes 2 pot of water or more to make a full pot
I recommend slowly pouring in about a half a pot of cold water without coffee in the filter basket 5 or so minutes before you brew in the morning. There are 2 good reasons to do this-
1. Overnight you are having some evaporation due to the fact that your Bunn brewer has a reservoir that keeps a couple of pots worth of water at brewing temperature... a better temp than most "home" model brewers. This will top off the reservoir and you will not "short pot" except for the amount that the grounds themselves hold back.
2. Also overnight, due to the fact that the water is kept hot, the oxygen can dissipate from the water in the tank. Topping off with fresh water will mean a fresher first pot.
The Bunn brewers have a low wattage/keep warm heater so the actual heating element isn't doing all of the work over those long periods... it only kicks on when the temperature in the reservoir drops considerably (like after brewing). Be sure to let the brewer heat back up before brewing (you will hear it stop heating)
Hope this helps.
Oct 28, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
When the water cycle is running there is a white plug by the water inlet that is leaking. When the dishwasher is not in the water cycle it does not leak. When the dishwasher is stopped in the middle of the...
crack in water inlet valve or a pin hole in the hose going from the valve to side of tub spraying water where you see it. You have a holein someting. You need to trace it back to its sourse. When you say "water is running"im guessing thats when its filling with water not just washing.
Oct 30, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Coffee pot leakage
Have you contacted Hamilton Beach to file a complaint? Or the BBB website? If there is a manufacturer defect with the unit and enough people complain they will need to remedy the problem or refund money. If you have been reading that there are other people with the same problem and it is not isolated then I would return the cofee pot and get a different model/brand. Check a site like www.epinions.com that allows people to rate products they are using. I use them all the time before I purchase a product.
Oct 03, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Cant solve puzzle 100 in professor layton cant go on im desperate
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Whirlpool Fridge has water leakage
have you been filling it up with more food than usual? how are you storing the food? if its touching the back of the fridge then this causes the water to drip down the back and accumulate at the bottom. I had the same problem (different fridge), I'd open the fridge and there;d be a pool of water at the bottom, sometimes it even started leaking out onto the floor.
so... i just made sure when i put food in that it wasn't all pushed to the back and that none of it was touching the back of the fridge - no more water at the bottom!
give it a try , hope this helps.
Jul 31, 2008 | Whirlpool Refrigerators
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Keurig B60 Coffee Maker Logo
64 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
