Question about Linear Corporation ACP00878 Linear MDKP Exterior Wireless Keypad for home security
Control Box Mounting Plate
Out keypad box got hit and it damaged the mounting plate where the keypad box locks to the plate. Is it possible to order a replacement back plate for this model? If so any information you can provide would be helpful. Thanks, Rob
    New Friend:
  • 4 Answers
No, manufacturers do not distribute parts of keypads. The keypad will have to be replaced entirely.
Posted on Jun 28, 2014
Ceiling mounting plate
You can purchase ceiling plates and other related hardware at a "big box" retailer or well stocked hardware store.
Aug 16, 2016 | Dryers
I have a 98 F800/5.9 cummins. Pumper truck w/bationi pump. Pto leaking. How do I know what to order.please. help
you are not specific about where the pto is leaking. If it hoses to the pump then replace the hoses and fittings.If it leaking between the pump and the gear box then you will need 2 gaskets. There is a gasket that goes between the adaptor plate and the box opening and another between the pump and the adaptor plate. Use good quality gasket goo( silastic blue ). Ensure that and mounting bolts that go through into the oil section of the box are sealed around the threads or have good copper washers under the heads. If the installation was done correctly initially then it is possible that le leakage is from loose bolts
Dec 17, 2014 | Cars & Trucks
Back mounting plate
I'm not familiar with the particular system you have but I would call the manufacturer and see if it is something you can order. For some systems you can order back plates, mounting plates ect.. and for others you have to order the whole unit.
Mar 28, 2014 | Linear Corporation ACP00878 Linear MDKP...
Broan-Nutone 750 V springs
I think you have a mismatched set. The ceiling box is wrong. It should also be round on a 750 style
Apr 10, 2017 | Dryers
Tag light is not working. is there a fuse that will get the light turned back on?
The fuse labeled REAR PARK LP 15A in the right instrument panel fuse box powers the rear park lamps, and the tag lamps. If your rear park lamps are working then you most likely need to replace the tag lamps (bulbs). Use the following procedure to replace the lamps.
To Remove:
  1. Remove the two mounting screws from the license plate lamp.
  2. Remove the license plate lamp from the rear bumper fascia.
  3. Remove the license plate lamp socket by turning it counterclockwise.
To Install:
  1. Install the license plate lamp socket by turning it clockwise.
  2. Position the license plate lamp to the rear bumper fascia.
  3. Install the license plate lamp mounting screws.
Feb 17, 2011 | 2004 Chevrolet Impala
Is it difficult to replace the headlight switch on my 87 Chrysler 5th Ave.? When I turn-on the headlights, they don't turn-on real good...I have to pull the switch out, fully, several times for them to...
Pretty simple actually....here is the directions on how to do it:
  1. Remove the headlamp switch bezel from the instrument panel by unsnapping the attaching tangs.
  2. Remove the 3 screws securing the switch mounting plate to the instrument panel, then pull the switch and mounting plate rearward and out of the instrument panel opening.
  3. Disengage the electrical connector at the switch. Press the release button on the bottom of the switch and then pull the knob and shaft out of the switch.
  4. Detach the headlamp switch escutcheon from the mounting plate by unsnapping the attaching tangs and removing it, then unscrew the switch-to-mounting plate retaining nut and pull the switch off the mounting plate.
To install:
  1. Position the switch onto the mounting plate and install the retaining nut, then snap the headlamp switch escutcheon back into position.
  2. Slide the knob shaft into the switch until it locks. Reattach the switch electrical connector.
  3. Install the mounting plate onto the instrument panel. Install the 3 attaching screws.
  4. Snap the headlamp switch bezel back into position.
Nov 01, 2010 | 1987 Chrysler Fifth Avenue
No ground wire on the dimmer switch what do I do with the ground wire coming from the box
Place it under the mounting plate where the 2 mounting screws mount to the wall box.
Feb 20, 2010 | Lutron #D-600PH-DK 600W SP Push Rotating...
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Mar 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Linear Corporation ACP00878 Linear MDKP Exterior Wireless Keypad for home security Logo
99 people viewed this question
Top Linear Corporation Home Security Experts
Lawrence Oravetz
Are you a Linear Corporation Home Security Expert? Answer questions, earn points and help others
