Question about Linear Corporation ACP00878 Linear MDKP Exterior Wireless Keypad for home security
Back mounting plate
Hello our control panel got hit and the plate that mounts the control box to the pole was damaged at the catch where the box attaches to the plate with the lock. Is it possible to order a new mounting plate for this unit?
    New Friend:
  • 57 Answers
I'm not familiar with the particular system you have but I would call the manufacturer and see if it is something you can order. For some systems you can order back plates, mounting plates ect.. and for others you have to order the whole unit.
Posted on May 17, 2014
Control Box Mounting Plate
No, manufacturers do not distribute parts of keypads. The keypad will have to be replaced entirely.
Mar 28, 2014 | Linear Corporation ACP00878 Linear MDKP...
Kenmore digital oven model 79095321303 temperature is wrong. Digital display on oven says 350 degrees but oven thermometer placed in center of oven (middle rack) shows 200 degrees. When I up the...
It could be one of two things either the control board or the temperature probe and I suspect the probe and that is a do it yourself job.
The oven temperature sensor on your Kenmore range is a one-piece unit that mounts to the rear oven wall with a mounting plate. The sensor is not difficult to change. You will need to dismantle the rear panel from the oven to access the mounting plate. Most appliance repair shops will have replacement sensors. It is a good idea to take the old sensor with you along with the model number of your oven. This way you will be sure to get the correct replacement sensor for your oven.
  • Unplug the Kenmore oven power cord from the wall outlet. Move the oven range away from the wall so that you can access the back of the unit. (Ask a friend to assist you to move the oven. if necessary.) The oven may use an anti-tip bracket on one of the rear legs. Push the oven toward the back wall to release the leg from the bracket in the floor. Tilt the back of the oven toward you, and pull the oven forward.
  • Remove the screws that secure the back panel to the oven with a Phillips-head screwdriver. Pull the back panel away from the unit and set the panel out of the work area.
  • 3
    Locate the mounting plate for the oven temperature sensor on the upper right side of the back of the oven. There will be a single wire coming from the back of the mounting plate and the wire mounts to a clip.
  • 4
    Follow the wire to the connector on the other end. Pull the connector on the wire to disconnect the wire from the wiring harness.
  • 5
    Remove the two screws that secure the mounting plate to the rear of the oven with a Phillips-head screwdriver. Pull the temperature sensor straight out of the oven. Unclip the sensor wire from the mounting clip.
  • 6
    Take the oven temperature sensor to an appliance repair facility to purchase a replacement. Insert the sensor end of the temperature sensor through the hole in the back of the oven. Slide the sensor all the way until the sensor mounting plate is flush against the oven. Secure the sensor with the two mounting screws.
  • 7
    Connect the sensor wire to the connector by pushing the connector until it locks in place. Snap the wire inside the retaining clip.
  • 8
    Place the back panel back over the rear of the oven and secure the panel with the retaining screws. Slide the Kenmore oven back into its working position and plug the power cord into the wall outlet.
  • Oct 09, 2011 | Ovens
    How to change fuse for lg lrm1250W
    Hello
    Get beneath the LG microwave, and grasp it on the bottom at either end. Lift the microwave up slightly, and pull it out from the wall to remove it from the mounting plate.
    Turn the microwave onto its face on a soft rug or blanket. Remove the screws from the back panel of the microwave, and slide the panel upward to take it off the unit.
    Look for the three fuses in the LG microwave -- one at the lower-right corner, one in the upper-right corner and one in the top center. Check each of the fuses to see if any of them look dark in color; this indicates a burned-out fuse.
    Remove the burned-out fuse by gripping it firmly and pulling it away from the wall of the microwave. Once the fuse is removed, press the new fuse into the same position in the microwave until it clicks into place.
    Slide the back panel onto the microwave, and replace the screws. Lift the microwave into the space beneath the cabinet from which it was removed, holding it slightly higher than the mounting plate, and lower the microwave until it catches on the mounting plate.
    Oct 05, 2011 | LG LRM1250 Microwave Oven
    Casing on off switch plastic mount on side of tv broken. on off switch dropped inside
    Hello, you're supposed to put the TV on the screen carefully. Remove the screws of the lid back and assess the damage. Usually it is possible to catch the break, or improvise in any way, the switch back in place.
    Let me know if it worked out, or if you need additional guidance
    Mar 06, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
    I need to replace a blower motor on a 1998 GMC Sierra 2500 6.5L diesel. Could you tell me how to go about it, how much of the dash do I have to remove? Thanks
    To Remove:
    1. Disconnect the negative battery cable.
    2. Remove the glove compartment from the instrument panel.
    3. Remove the front screw from the right door sill plate.
    4. Remove the right kick panel trim.
    5. Disconnect the electrical connectors from the powertrain control module (PCM), as needed. Remove the PCM and mounting bracket if equipped with a diesel engine.
    6. Disconnect the electrical connector from the blower motor.
    7. Remove the bolt from the right lower instrument panel support.
    8. Remove the blower motor cover.
    9. Remove the blower motor cooling tube.
    10. Remove the blower motor mounting flange screws.
    11. Carefully pull the blower motor forward in order to avoid distorting the fan and pry back on the right side of the instrument panel to as necessary to remove the blower motor.
    To Install:
    1. Guide the blower motor assembly into position. Avoid catching the blower fan on any protruding parts.
    2. Install the blower motor mounting screws.
    3. Install the blower motor cooling tube and blower motor cover.
    4. Install the bolt in the right lower instrument panel support.
    5. Connect the electrical connectors, as necessary.
    6. Install the mounting bracket and the powertrain control module (PCM) if removed.
    7. Connect the electrical connectors to the PCM, as necessary.
    8. Install the right kick panel trim.
    9. Install the screw into the front door sill plate.
    10. Install the glove box in the instrument panel.
    11. Connect the negative battery cable.
    12. Check the operation of the blower motor.
    Feb 03, 2011 | GMC Sierra 2500 Cars & Trucks
    I needed to replace climate control unit on1997 Grand Am GT. Concerned with how to remove the cluster face panel w/o breaking it.
    Let me know if this helps out.
    Heater & Air Conditioning
    2. Remove the screws securing the cluster trim plate to the instrument panel.
    3. Tilt the top of the cluster trim plate downward releasing the clips that mount the bottom of the trim plate to the dash. Remove the trim plate.
    4. Remove the screws attaching the accessory trim center plate to the dash.
    5. Tilt the top of accessory trim plate downward releasing the clips that mount the bottom of the plate to the instrument panel. Remove the plate.
    6. Remove the screws attaching the control assembly to the dash.
    7. Remove the control assembly from the dash.
    8. Disconnect the control assembly electrical connectors.
    9. Remove the control assembly.
    To install:
    1. Install the control assembly.
    2. Connect the control assembly electrical connectors.
    3. Install the control assembly attaching screws.
    4. Push the mounting clips into place and roll the top of the accessory trim plate upward into position.
    5. Install the screws attaching the accessory trim plate to the dash.
    6. Push the mounting clips into place and roll the top of the cluster trim plate upward into position.
    7. Install the screws attaching the cluster trim plate to the instrument panel.
    8. Connect the negative battery cable.
    // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 40; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
    Jan 23, 2011 | Pontiac Grand Am Cars & Trucks
    Is it difficult to replace the headlight switch on my 87 Chrysler 5th Ave.? When I turn-on the headlights, they don't turn-on real good...I have to pull the switch out, fully, several times for them to...
    Pretty simple actually....here is the directions on how to do it:
    1. Remove the headlamp switch bezel from the instrument panel by unsnapping the attaching tangs.
    2. Remove the 3 screws securing the switch mounting plate to the instrument panel, then pull the switch and mounting plate rearward and out of the instrument panel opening.
    3. Disengage the electrical connector at the switch. Press the release button on the bottom of the switch and then pull the knob and shaft out of the switch.
    4. Detach the headlamp switch escutcheon from the mounting plate by unsnapping the attaching tangs and removing it, then unscrew the switch-to-mounting plate retaining nut and pull the switch off the mounting plate.
    To install:
    1. Position the switch onto the mounting plate and install the retaining nut, then snap the headlamp switch escutcheon back into position.
    2. Slide the knob shaft into the switch until it locks. Reattach the switch electrical connector.
    3. Install the mounting plate onto the instrument panel. Install the 3 attaching screws.
    4. Snap the headlamp switch bezel back into position.
    Nov 01, 2010 | 1987 Chrysler Fifth Avenue
    Hit curb while turning, tire rubs firewall
    If you did not damage the frame, you more than likely damaged the lower control arm (a triangle shaped aluminum part which mounts to steering knuckle(tire side) and two bushing mounts (To frame) Check the condition against the undamaged side. If the control arm is damaged see if you can get one from a junk yard. If you do replace any part yourself Get an alignment immediately after repair.
    Oct 14, 2009 | 1999 Pontiac Grand Prix
    Dash
    REMOVAL & INSTALLATION
    2. Remove the ashtray.
    3. Unfasten the accessory trim plate screws, then remove the accessory trim plate.
    4. Remove the glove box door strap, then remove the glove box hinge screws.
    5. Remove the glove box door frame.
    6. Loosen the ashtray support screws, then remove the ashtray support.
    7. Remove the glove box.
    8. Unfasten the radio bracket bushing nut, then remove the radio.
    9. Disconnect the speaker grille screws, then remove the speaker grilles.
    10. Loosen the speaker retainers, then remove the front radio speakers.
    11. Unfasten the sound insulation panel screws, then remove the sound insulation panels.
    12. Loosen the steering column filler screws, then remove the steering column filler.
    13. Disconnect the hood release cable.
    14. Disconnect the shift indicator cable from the column bowl.
    15. Disconnect the steering column support nuts, then lower the steering column. For details regarding this procedure, please refer to of this guide.
    16. Unfasten the switch plate trim screw, then remove the switch trim plate.
    17. Disengage the electrical wiring harness from the rear defogger and the light switches.
    18. Disconnect the heater and A/C control.
    19. Disconnect the cluster housing bezel mounting nuts, then remove the bezel.
    20. Remove the instrument cluster from the vehicle. Disconnect and allow to hang:
    21. The speedometer instrument panel electrical connector and the Vehicle Speed Sensor connector
    22. The courtesy lamps and the cruise control module
    23. The horn relay, multi-function alarm and the flasher assembly
    24. If necessary, remove the applicable computer control module.
    25. Remove the instrument panel-to-cowl mounts:
      1. Unfasten the screws from under the panel.
      2. Remove the instrument panel support.
      3. Unfasten the screws in the defroster outlets.
      4. Remove the ductwork, dash plugs, wire looms, and heater cables attached to the panel.
    26. Disengage any electrical connections/wires routed through the instrument panel, then remove the instrument panel from the vehicle.
    To install:
    1. Install the instrument panel assembly to the cowl, carefully routing and connecting the electrical wires and cables.
    2. Connect the instrument panel-to-cowl mounts:
      1. Connect the ductwork, dash plugs, wire looms, and heater cables to the instrument panel.
      2. Secure the screws in the defroster outlets.
      3. Install the instrument panel support, then fasten the screws (located under the panel).
    3. Install the computer control module, if removed.
    4. Install the instrument cluster. Reconnect and mount:
    5. The speedometer and Vehicle Speed Sensor electrical connectors
    6. The flasher assembly, multi-function alarm, and horn relay
    7. The cruise control module and the courtesy lamps
    8. Install the cluster housing bezel using the mounting nuts. Tighten the nuts to 12 inch lbs. (1.4 Nm).
    9. Install the heater and A/C control.
    10. Engage the rear defogger and light switch electrical harness.
    11. Install the switch trim plate using the retaining screw. Tighten the screw to 12 inch lbs. (1.4 Nm).
    12. Raise the steering column to the mounting bracket, then install the steering column support nuts.
    13. Install the shift indicator column to the column bowl, making sure that the indicator is aligned.
    14. Connect the hood release cable.
    15. Install the steering column filler panel using the retaining screws. Tighten the screws to 14 inch lbs. (1.6 Nm).
    16. Install the sound insulation panels using the retaining screws. Tighten the screws to 14 inch lbs. (1.6 Nm).
    17. Install the front radio speakers and speaker retainers, then connect the speaker grilles using the retaining screws. Tighten the screws to 12 inch lbs. (1.4 Nm).
    18. Install the radio and tighten the fastener to 12 inch lbs. (1.4 Nm).
    19. Install the glove compartment, then install the ashtray support using the retaining screws. Tighten the screws to 12 inch lbs. (1.4 Nm).
    20. Install the glove compartment door frame, door and door hinge screws. Tighten the screws to 12 inch lbs. (1.4 Nm).
    21. Install the glove compartment door strap.
    22. Install the accessory trim plate using the retaining screws. Tighten the screws to 12 inch lbs. (1.4 Nm).
    23. Install the ashtray, then connect the negative battery cable.
    Oct 02, 2008 | 1989 Chevrolet S-10 Blazer
    Hello
    This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
    Even though a door switch clicks, it may still be bad inside.
    It may have been damaged in shipping.
    In an oven that's not new, this can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
    Since it's under warranty and very new, I would take it back to the dealer for a new one.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Nov 26, 2007 | Microwave Ovens
    Linear Corporation ACP00878 Linear MDKP Exterior Wireless Keypad for home security Logo
    Top Linear Corporation Home Security Experts
    Lawrence Oravetz
    Are you a Linear Corporation Home Security Expert? Answer questions, earn points and help others
