Question about HP LaserJet 4200n Printer
Definition of the printer 4200n - HP LaserJet 4200n Printer
    New Friend:
  • 78 Answers
Not sure what you want to know.4200n is the model number with the n denoting networked.
Posted on Apr 15, 2014
I have a HP 4000n printer and want it to print from tray 3 when tray 2 is empty. It doesn't do that now.
I don't have a 4000n, but I do have a 4200n that should be relatively similar. On the 4200n you can change this behavior by going to the menu, then Configure Device->System Setup->Tray Behavior->Use Requested Tray, then setting that value to First. My guess is you have that setting on your 4000n set to Exclusively, which will then prevent the job from going to a different tray. It also requires that you have the same type and size of paper registered in both trays if you want the job to automatically switch over.
If that menu path is different on your 4000n you just need to dig around in that menu to find the tray behavior setting.
Jun 09, 2011 | HP LaserJet 4000n Printer
HP LAZERJET PRINTER 4200N. WHEN PRINTING, LEAVES INK MARK DOWN ONE SIDE OF PAGE.
you may need to poke down the absorber foams below the ink cartridges. See if accumulations of blotted ink takes place. Wipe it or spray some windex. You may also need to wipe the roller with dampened clothe. Printed of the ink cartridge ma also need to be clean. Softly press it in a towel moistened with alcohol to remove ink residue in the print head.
Feb 02, 2011 | HP LaserJet 4200n Printer
Hp laserjet 4200n has an error code of 49.4c06 service error what do i do to fix this?
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | HP LaserJet 4200n Printer
What is the replacement procedure jetdirect card hp 4200n? Does anything need to be reconfigured after the replacement?
You may have to reenter the IP address sub net etc. One of the easier things to replace... -Carl Hinesburg Vt
Oct 14, 2010 | HP LaserJet 4200n Printer
I have a fault code of 50.2 fusion what is this and how do I clear tried switching on off but still shows
50.2 indidicate a possible faulty fuser or lack of power to the fuser.
If you have another LaserJet 4200n (must be same model, verify under the toner cover, by the serial #), swap the fuser assemblies by removing the back door (rear output access cover) and then releasing the fuser with the 2 blue locking tabs. When you reseat the fuser, it should click into place on both sides. Re-attach the door and test...if problem (error 50.2) moves to the other printer, you have a failed fuser, if issue remains on original printer, it is a power supply issue.
Jan 14, 2010 | HP LaserJet 4200n Printer
I have an hp 4200n that picks up an extra blank page when i print a menu map. the paper (blank page only gets up to the delivery assy past the fuser, no jam error). this happens when i print it from tray...
Hello, you must clean separation roller whit wet cloth or alcohol. Remove Tray 2, look for blue (usualy) cylinder feed rubber on it and clean Good luck. P.S You can clear paper feed roolers too (look at printer bottom after removing Tray 2) using same way!
Oct 15, 2009 | HP LaserJet 4200n Printer
My hp LaserJet 4200n prints multiple pages when only one is requested.
This can happen with a driver issue check what driver you have installed and if it is a PCL6 driver try using a PCL5 driver and see if your issue is resolved.
Sep 23, 2009 | HP LaserJet 4200n Printer
Hp laserjet 4200n printing blank page
Hi!
Please see the following link to resolve the issue you are facing with--
HP Laserjet 4200 Printer
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 27, 2009 | HP LaserJet 4200n Printer
New LJ 4200N Install
simply connect the rj45 cable and create the printer using hp network printer software. you can download it from the hp website
May 30, 2008 | HP LaserJet 4300n Printer
HP LaserJet 4200n Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
