Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave timer and light come on but makes no sound nor does the turn table works made by emerson
What does the capasterdor do
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Sounds like you have a bad door switch or it could also be the smart board.
Posted on May 02, 2014
SOURCE: Repairing Microwave
check high volatage circuit, and magnetron, and wiring and control unit or circuit...
Posted on Oct 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 23, 2009
  • 8404 Answers
SOURCE: I have a GE SpacemakerXL Microwave Oven
Check the door safety interlock switches.
Thanks for using FixYa.com
Posted on Dec 11, 2009
heatman101
  • 43501 Answers
SOURCE: Microwave Model JVM 1870 stopped heating, all else works (timer)
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ggk
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: microwave won't heat, appears to be on.
heatman101
jhdfs
Emerson Microwave MW9117W. Timer Counts down and turn table stops, but continues to hum as if microwave is still running. Have to unplug to stop it. Anyone know what problem is? Thanks
Sounds like you have a ''smart board" or door switch problem, try to un plug the product, push all the 'buttons' on the control panel and then plug the product back in, if this does not correct the problem you have a component that has failed.
Jan 09, 2015 | Emerson Microwave Ovens
Emerson microwave MW8103SS not heating up.
If the turntable in not turning, it's probably be a bad door switch or door switch mount.
See these links:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
If the turntable does turn, then it is probably a bad connection or component in the high voltage section.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 24, 2012 | Emerson Microwave Ovens
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Mar 21, 2011 | Emerson MW8107WA Microwave Oven
MMV4205 1150 Watts Microwave Oven: all boards and timers work will not heat food m...
heatman101
syjs
May 18, 2010 | Maytag MMV4205 Microwave Oven
We have a emmerson micro and the turn table cluncks
Problem fixed. Called number on micro and they were great in fixing the problem.
Oct 28, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
GE Microwave
sounds like either a powerboard or control board is sending erratic voltage or no voltage to the table motor and possibly the light.
May 29, 2008 | Microwave Ovens
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
