Question about Maytag Neptune MDE7500AY Electric Dryer
Dryer runs 20 mins, stops, must be restarted over and over. run time becomes less and less after each restart.
I disconnected vent or problem continues. I replaced motor 3years ago. I installed unit in 1991?
    Problem Solver:
  • 10 Answers
Check thermal switch on back of dryer,join wires together(tape with electrictape so i tdoes not touch body)then turn on,if runs properly there you go.or change timer
Posted on Apr 14, 2014
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Kenmore dryer 66812690 over heating
did you clean the inside venting circuit inside the dryer from the blower housing.lint trap etc if the dryers full of lint a clean outside vent system wont help
Oct 25, 2012 | Kenmore Dryers
Whirlpool 6 cycle dryer keeps shutting off. it will start back up and run, sometimes it will finish the load and most times it will shut back off in 5 to 20 min.
vent is restricted, disconnect vent tube run dryer. Clean out your restricted vent tube with a leaf blower and make sure it is not kinked or too long, this should help Tim:
http://www.applianceaid.com/general.html#vent
Mar 11, 2011 | Whirlpool Dryers
Roper dryer runs for about 5-10 min. then shuts off. After 10-15 min I can restart, but same thing happens. What up?
disconnect vent tube and run dryer, if it finishes the cycle then there is a restriction in the vent tube
Dec 26, 2010 | Whirlpool Dryers
My sears dryer will shot off when iy gets hot,going through its cycle. If i let it cool down for about 10 mins. I can restart and continue for another 20 mins before it shuts down again
Take the exhaust vent off the rear and try it.
If it runs OK,repair the vent blockage/restriction.
If it does not run OK,replace the motor.
Sep 27, 2010 | Dryers
My dryer stops running after a few minutes. The fuse has been replaced and the repair man replaced the motor and it stills runs for a few minutes then stops. HELP!
Did you clean it out too? Check the venting for clog behind dryer or at the vent cap? Is the house breaker clicking off? Is the dryer motor humming or just stopping? Does it restart every time you try or do you have to let it cool down for a bit to restart? Need more info to be sure. You may have a bad sensor, but you'll need a repairman to check that.
May 14, 2010 | Maytag Dryers
The igniter fires the gas, it burns for a minute or less, then stops and won't restart unless the dryer is stopped and restarted? Is this a coil problem?
Sounds like a clogged vent. If you let it run for a few minutes after it shuts off, it will come back on. Your overtemp. thermostat doesn't allow it to work, because the hot air is not being sucked in. But to answer your question, not the coils for sure in my opinion. When coils fail, it won't turn on after 10 min of running or more. Not right away.
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Maytag MDG9206 Dryer
It starts and runs for about 20 - 30 secondds then stops
Pwolf, looks like the problem you?re having is not with the dryer. The vent line is probably clogged up, which caused the dryer to overheat. The hi limit thermostat opens up which shuts off the dryer. After it cools down and closes, you are able to restart the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. If it doesn?t run with the hose disconnected, then you have to provide the complete model number, which is located on the door frame. Gendos....post back.
Dec 14, 2006 | Kenmore 64852 Electric Dryer
Maytag Neptune MDE7500AY Electric Dryer Logo
37 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
