Question about Vehicle Parts & Accessories
Oil leak drips at the oil filter
Slow leak forms dripping drops at the oil filter
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
Tighten the filter. If it can't be stopped, replace the filter.
Posted on Mar 28, 2014
Why is my 2002 Pontiac grand am dripping oil 1 drop every 5 seconds only while the engine is running following an oil change?
sorry would need to see it to know the problem ,but i have had it where the oil filter itself wasnt made properly and it leaks on the crimped seal on the filter .
Sep 27, 2016 | 2002 Pontiac Grand Am
Oil leak between oil pan and transmission.
Try running some of that high-mileage engine oil next time you do an oil change (it helps to swell engine seals slightly). If the problem clears up or is reduced, then it's likely that the rear main oil seal is starting to leak a little. The rubber seals will harden up and shrink a little with age.
I would also powerwash the entire area clean, so that way any leak will be easier to monitor and pinpoint.
Feb 24, 2013 | 1999 Chevrolet Silverado 1500
WHAT TO LOOK FOR IF THE IS ENGINE LEAK
I'm presuming an oil leak?
Check around the sump where it bolts to the bottom end. Visually inspect the sump for holes (altho you would be losing oil pretty severly if there is). Check around the oil filter, might not be sealed right.
One way to narrow the leak location is get a sheet of card and put it on the ground under the engine bay overnight. It should show you where the oil is dripping from or what its dripping off.
Also Accents have a habbit of dropping oil level very quickly when they are getting close to requiring an oil top up.
Dec 05, 2012 | 1999 Hyundai Accent
Hi, I have a fiat doblo cargo 2003, leaking oil. When I park up - the oil drips closer to (but not right at) the front of vehicle, and to the left hand side (drivers' side) - could this be the oil...
Try wiping the engine off in that area with some rags, then watch for where the oil leak comes from. If it's the filter seal, you should see oil on the filter dripping off.
Oct 08, 2012 | Cars & Trucks
1992 Silverado K1500 Blazer pissing out oil around oil filter adapter...Want my truck back please help
Hoses going to filter adapter are bad about leaking, and factory parts are expensive. If you carefully cut the crimp fittings off, you can use oil remote cooler type hose and clamps to fix it.
Aug 05, 2017 | Chevrolet Blazer Cars & Trucks
I Have An Oil Leak I noticed it about 4 months ago.. at first it only dripped oil after i was done driving my car.. but recently i noticed that whenever im driving the oil is dripping out faster making a...
first is to check the oil pressure switch (near the oil filter)(cheap) if its not that the oil pan and the bottom half of the block can leak (famous Northstar leaks) (BIG $$$)
Aug 29, 2011 | 2000 Cadillac DeVille
My 1996 Toyota Camry is leaking oil in little spots on the ground when its parked, where could it be leaking from and how can i fix it?
You cannot repair the leak until you determine where it is leaking. More than likely it is leaking from the oil filter, oil pressure sending unit, or valve cover gasket. Check around the oil filter for a leaks and if you see oil on the filter then replace it. Check the oil pressure sending unit and if it is leaking replace it. Wipe all the oil off the bottom of the engine and any other place you see oil. Now place newspapers on the floor under the car and then start the engine and let it run for about 10 minutes and then shut down. Wait overnight and you can see where the leak is coming from.
Mar 22, 2011 | Toyota Camry Cars & Trucks
Oil leaking,changed oil driving home 1,5 miles oil leked out filter tight and plug in drip pan
The gasket on the oil drain plug in the oil pan may have dropped off when it was removed and/or the filter may be installed with two gaskets.
Sep 19, 2010 | 1998 Saturn SL
Looks like tranny fluid drip originates between oil pan and tranny bell housing extremely slow leak,all fluids are level,any input 2004 jeep wrangler x
well the only two places it can be leaking form are the front tanny seal or the pump seal if its minor leave it for now, because to fix it you have to remove the transmission.
Jan 19, 2010 | 2004 Jeep Wrangler
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Vehicle Parts & Accessories Logo
75 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
