Question about Krups Kitchen Appliances - Others
Krups bw750d does not stay on
On switch does not stay on
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Coffee maker stays always on. i have to unplug the unit
the electronic board that sits behind the on off switch and controls is blown out probably lightening or power spikes I have replaced that piece a couple of times on both of our 229 coffee makers..We are in Colorado and lightening kills a lot of our electronics.....I cannot find that replacement part any more ...used to find it on smallaplliances.com not a good answer, but what is going on with your Krups we have had two 229's for over 14 years,,so I have replaced almost every part in them...
Oct 26, 2013 | Krups Aroma Control 229 Coffee Maker
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
The toaster was turned upside down and now it will not heat. The carriage does stay down
Sfety switch needs reset. Open the bottom and look for a switch in the cord wires circuit.
Sep 07, 2009 | Krups 287 SensoToast Deluxe 4-Slice...
I lost my user manual for a Krups ProAroma453-71 coffee maker. Where can I find one?
Contact Krups, and they should be able to send you out a new one. Their phone number (according to their website, www.krupsusa.com ) is 1-800-526-5377
Good luck! :)
Aug 26, 2009 | Krups ProAroma 453-71 Coffee Maker
Krups V70 Iron - stopped working
Sand points on temperature control switch.
Jul 07, 2009 | Krups V70 Iron
Krups 229 Aroma control switch is broken
Hi john you need to replace circuit board that has timer and auto shut-off I have same problem krups doesn't think it is a safety issue because the coffee maker has a thermal switch. But I still think it is. Also if you are not carefull when you fill with water it will staem back in your face!
SmallAppliance.com has special order replacement boards.
I will be replacing mine
Jul 04, 2009 | Krups Aroma Control 229 Coffee Maker
Kitchen Appliances - Others Logo
158 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
