Question about Bernina Sewing Machines
Change drive belt
How do I check the belt on a Bernina 708
    Scholar:
    New Friend:
  • 47 Answers
Setting the belt tension on the 707-708-717 machines with the old rubber "Continental" belts:
1. Make sure that the hand-wheel spins freely on the main-shaft bushing stub when the release knob is loosened.
2. Assuming that you are using the original 441mm "Continental" rubber v-belts, the setting is made by means of loosening a 5mm Allen socket cap screw at the base of the step pulley support.
_____________
NOTE: The hand-wheel, stepped pulley, and motor pulley v-grooves must be clean. This is to say, that they cannot have any particulate or threads wrapped around the grooves.
4. The pulley will be automatically pre-tensioned to a 7 o'clock position by means of a spring to maintain the stepped pulley position. By pulling the belt toward this 7 o'clock position, the pulley tension can be adjusted and then tightened by means of the fixing screw.
_____________
5. It is important to know that both the upper and lower belt tensions can be independently adjusted so as to allow the hand-wheel to spin freely for bobbin winding without having the hand-wheel drive the machine. This is done by adjusting the step pulley support + or - radially, near the 7 o'clock position.
If the hand-wheel drives the machine with the upper belt loosened, then either the belt is too tight or the hand-wheel bushing and main-shaft stub need cleaning and lubrication.
Note: Lubrication was once the standard factory procedure with a class 68 oil, but experience dictates a dry lubrication with graphite. Silicone lubes are not recommended.
6. Do not over-tighten the 5mm Allen fixing screw as the 5mm threaded frame boss can be broken off.
Adjusting with the original Polyurethane v-belts on models 807-801-810-817-811 machines:
1. Follow the same procedure as mentioned but allow the step pulley's positioning spring provide the belt tension. Nothing more is required here.
NOTE: Sometimes these belts and pulleys get oily thus allowing much slippage. A simple cleaning of the belts and pulleys with mineral spirits can solve this problem.
After-market belts:
NOTE: One can find after market belts that serves to drive these machines but not without some problems as they are usually wider belts and don't fit the pulleys well. In this case some adjustment will be necessary.
SewTechnical Home
Posted on Jun 24, 2014
Why would my Bernina 880, 10 months old, not boot up?
While the surge protector is an excellent thing to use, BERNINA sewing machines also have a set of fuses in the power supply. There is a chance that one of these fuses has blown. My recommendation would be to take your machine into your local BERNINA dealer to get it checked out. As long as you have checked the cord, the surge protector, changed plugs on both, and checked the circuit breaker in the house, it is probably an internal issue that is best fixed by a certified BERNINA technician.
You can find a nearby dealer, at the enclosed link or go to the store where you purchased your machine.
Find Dealer easily find your nearest BERNINA dealer BERNINA
Nov 02, 2015 | Bernina Sewing Machines
How do I change the motor drive belt on a Bernina 1030?
Adjustment: The stepped pulley support/frame has two 5mm fixing screws on the lower end of the frame and a plastic screw on the upper frame end. Early models had a third screw on the upper side of the frame. By loosening the screws slightly, push the stepped pulley and frame frame toward the loosened side and then let go,...tighten the screws. The frame tension spring is generally sufficient to adjust the belt tension. However, you may want to add a little tension but do not load too tight as you can cause stress on the motor or damage the front motor shaft bearing.
If a belt is needed, you can find them from local companies dealing in bearings, pulleys and drive components, i.e. Kaman Industrial etc. If memory serves me correctly the belt type is MXL, 250mm length, 5mm wide. The outer side of the belt has information to tell you the type. If you want to find one online go to www.sdp-si.com.
http://www.sewtechnical.com/
Apr 05, 2015 | Bernina Sewing Machines
Main motor will not turn on
When before used not happened check for trace. So still won't turn on the machine. Or motor over heat stop too and new belt die at . Therefore change a new belt or buy a new motor.
Dec 19, 2013 | Bernina Artista 180
Needle won t move up or down
There is a belt drive in some sewing machines. your belt may have slipped off or broken.
Sep 11, 2013 | Bernina Sewing Machines
Bernina 708 sewing machine
if you don't have a manual that tells about oiling, then contact bernina customer service and ask them if the sewing machine is self oiling or if you can oil it your self..
or here is a link for a manual, not sure if it will cover your
but it is free
http://www.bernina.com/getdoc/2f5d7505-d65a-42fd-b9a4-ef4e84046480/BERNINA_707_717_manual
Jul 18, 2013 | Sewing Machines
How to change belt on bernina overlocker
Carole... I recommend taking the overlocker in to have this done. If it's not done properly you could break a looper or worse with it being out of time. Better to have the belt replace and while you are at it have it cleaned, lubed and adjusted. ;)
Aug 08, 2012 | Bernina Sewing Machines
I have a 40 year old bernina 830. While trying to check the belt I accidentally opened up the belt assemble. I have put it back but want to confirm the correct sequence in which to put the pulley back. In...
Look here: http://rapid-pdf.com/saveas1.asp?PID=93b34769-41d5-48ec-b3da-7d9c66a14acc&lbd=1&lang=EN&ts=1/21/2011%2010:33:40%20AM&q=bernina%20830%20manual%0D%0A&cr=1
Jan 21, 2011 | Bernina Sewing Machines
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
Drive belt
I have taken the side off but I don't know what the adjuster looks like and what do I do with it when I do know what it looks like? Thank you for trying to help. Linit
Jul 23, 2008 | Sewing Machines
Sewing Machines Logo
206 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
