Question about Lenovo IdeaPad Z570 Notebook
0xc00000e9 error code...recovery screen only f8 or enter as only options
    Sergeant:
  • Lenovo Expert
  • 446 Answers
Might need to reinstall OS
Posted on Apr 07, 2014
Fix-ya
Press/tap F8 when starting to access Advanced boot options - select safe mode with command prompt - type chkdsk /r (make sure you leave a space between the k and / then hit enter.The error indicate a hard drive issue.Failure may be imminent or have occurred already.If you get it going again clone your drive to a new one.If it has failed hopefully you created restore discs.
Aug 27, 2014 | Toshiba Satellite Computers & Internet
Windows error 0xc00000e9
This error is sometimes an indication that the hard drive may be failing.Complete the following steps to check the integrity of your hard drive. If you are unable to get to the Advanced Boot Option menu using the F8 key, you will need to obtain a Windows Vista disc.
1.Restart your computer, tapping on the F8 button until you reach the Advanced Boot Options menu.
2.Select Safe Mode with command prompt.
3.Type chkdsk /r (there is a space between k and /)
Sep 12, 2013 | Dell Inspiron Computers & Internet
Computer won't boot stuck in Error RecoveryScreen won't go any further
You should be able to do a clean install of Windows. Just insert the installation disc and press any key when indicated. Optical drive needs to be the first boot option. Go into BIOS and change it is not.
As for disc, you have to use the same Windows version as indicated on the MS Product Key sticker, because of the serial number.
May 24, 2013 | Toshiba NB205-N210 Netbook
Returned back to its factory settingss
Press F8 repeatedly at start up black screen before logo or log in screen to enter start options chose safe mode back up all important files restart pressing F8 and chose recovery or repair.
Go to http://www.ehow.com/how_5007576_make-lenovo-recovery-cd.html
Apr 11, 2013 | Lenovo G560 0679 Notebook
Oxeoefoooe
Method 1:
I would suggest you to check of you can open the system recovery options without using the installation disc- a. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button. b. Do one of the following: If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer. If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8. c. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.
c. Select a keyboard layout, and then click next.
d. On the System Recovery Options menu, click a tool to open it. Refer the below link for more information -
What are the system recovery options in Windows 7?
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 Method 2:
If the repair option is not present in the advanced boot options and you are unable to perform the recovery then in that that case there are no options other than getting the installation disc or contacting Hp for assistance.
The error code you are getting while restoring to factory settings is some error associated with the hardware for Hp computer. You might need a tool or some hardware update from HP to get over the error.
You may use the below link and check diagnostic tool update assists you resolve the issue -
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=pv-77569-1&jumpid=reg_R1002_USEN For further assistance you may contact HP using the below provided link -
http://welcome.hp.com/country/us/en/support.html
Mar 05, 2013 | HEWLETT-PACKARD COMPAQ PRESARIO CQ5700F...
Error code on compaq presatio desktop oxeoef000e
Method 1:
Mar 05, 2013 | Computers & Internet
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
Status: 0xc00000e9 acer vista faulty hardware
You didn't supply the Make, Model of Laptop or the OS you are using?Remove ALL media, CD, DVD, USB, Unplug , remove battery, plug in , If you can do a restore/recovery procedure. If that fails, open the laptop and reseat the HDD and Memory Mods. I don't know how old your laptop is , Can you open the BIOS? Is the CMOS battery good? Have you tried a OS Repair Disk? Need more info, have you seen this: http://answers.microsoft.com/en-us/windows/forum/windows_7-system/unexpected-io-error-has-occured-status-0xc00000e9/ca21de58-4b0d-4f4c-b110-3788fd534e8a
Dec 20, 2012 | Computers & Internet
Lenovo IdeaPad Z570 Notebook Logo
67 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
