Question about Vehicle Parts & Accessories
Oil leak - Vehicle Parts & Accessories
  • william rodriguez Mar 31, 2014
    Hi Stephen Winters, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Sergeant:
  • 221 Answers
In a dry area of a garage or flat road way.
Place a piece of Cardboard underneath the car.
Leave a while and check to see what the location of the oil spot is.
When you see the spot go onto your back and look from underneath with a battery torch and see if you can identify where the drip is coming from.
Perhaps something was not tightened fully in which case tighten the part or it has made its way down the engine when something was filled recently or overfilled.
Posted on Mar 08, 2015
OIL LEAKING INTO THE SPARK PLUGS ON 2005 MALIBU CLASSIC
ENGINE OIL ISSUES/ OIL LEAK
The oil is getting leaked from its running area. The oil pump has to be pressure tested by pressure test to confirm the leak and area of leak: -----
For step by step troubleshooting check the help links mentioned below: -----
Click the link below: -----
Water in engine oil?
http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
High Oil Level on Dipstick
http://whatisbyme.blogspot.in/2012/06/high-oil-level-on-dipstick.html
Oil pouring out from left front of engine?
http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html
Common Causes of Car Oil Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Kia Sportage leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
Toyota Corolla leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Overfilling oil in engine?
http://whatisbyme.blogspot.in/2012/06/overfilling-oil-in-engine.html
2000 Dodge Ram 3500 Cummins Diesel: Oil Leak issues?
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
HOW TO RESET OIL CHANGE INDICATOR?
http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These details will help.
Thanks.
Dec 05, 2012 | Chevrolet Cars & Trucks
Oil in the radiator
Thanks.
Nov 28, 2012 | Cars & Trucks
My 2001alero has been leaking oil. I was driving down the road and it didn't have any power. Ipushed the gas pedal to the floor and the car didn't Rev up at all and it acted like it wanted to shut...
Click this link below for oil leak and rev issues:-----http://repairhelpcenter.blogspot.in/2012/02/car-has-oil-leak-and-shuts-off-at-rev.html
For oil leak problem,click the link below.This are direct hel links to troubleshoot the problem :-----
Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Car Turns OFF due to low oil pressure warning light?http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil leaks from air filter ?http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Rear oil seal leaking?http://schematicsdiagram.blogspot.com/2011/12/rear-oil-seal-leaking.html
This will help.
Feb 13, 2012 | 2001 Oldsmobile Alero
Oil leak
How long is a piece of string ? without a good look under the bonnet i couldnt say but make sure the engine breather is clean and not clogged as this would cause a build up of back pressure which will cause the oil top leak from everywhere possible
Feb 08, 2012 | 1988 Chrysler LeBaron
I have mazda 6 2004....earlier i have radiater leak...then i repaired...then again it started heavy fuel consumtion...and chek engine indicator appears on dash board...i have engine oil leakege also..
FOR oil leak issue and other problems you mentioned check the following help links:---
Radiator leaking? http://repairhelpcenter.blogspot.com/2011/12/radiator-leaking.html
consuming more fuel? http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html--------- How to maximize fuel economy on your vehicle? http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html
Check Engine Light On car? http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Car oil leak?
Oil leaks from air filter on ford?http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
---------This will help. Thanks.
Jan 27, 2012 | 2004 Mazda 6
Why is my car leaking oil
its common for some automakers to leak oil, run badly, break often, & otherwise be a plain hassle............I would suggest reading consumer reports before buying new or used cars.
Jan 23, 2012 | 1996 Volkswagen Jetta
Vehicle Parts & Accessories Logo
71 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
