Question about Dryers
Candy cic60 eveything works but it dosnt heat up its blowing cold air what could it be
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
Your element
Posted on Apr 09, 2014
SOURCE: Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Posted on Oct 12, 2008
SOURCE: DRYER BLOWING COLD AIR-NOT HEATING UP
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
I hope this helps....
Posted on Jan 21, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
  • 15 Answers
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
My Candy CIC60 dryer works fine till my homes fuse box cuts off power. Longest it worked plugged in was less than minute. House is new built, so i don't think problem is there. Dryer is used for 2yrs.
  • Do not risk a house fire!
Candy CIC60 User Instructions
If all else fails, read the above.
Hummmm....
An Electrician might be needed. If you house is under warranty, you should read the fine print. Here is why.
It is possible that the breaker and/or wiring is under rated or defective. Check the amp draw rating on the breaker an compare it to the requirements of the drier. Installation / Operation link above If the drier is using the full amount of the breaker it will eventually weaken and fail to hold the load for as long as it did when new.
An experienced electrician will be able to determine if this is the case. Actual current draw should be measured while drier is in operation.
Replacing the breaker with a new one should fix it in that case.
Worst case would be that the wiring and the breaker are not of sufficient size to handle the load. This would be a HOUSE FIRE RISK as the wire is acting as a heating element. Again an electrician can make this determination by measuring the voltage drop of the wire from breaker to drier.
In the instructions included above, there is a phone number to the Manufacturer.
  • good luck!
Oct 04, 2016 | Candy Dryers
Fan oven blowing cold
The fan inside an oven is usually for convection cooking. It circulates air that is already heated. It is not a heater.
Apr 29, 2014 | Candy Ovens
Candy cic60 not giving hot air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Candy CIV60 Electric Dryer
The fan in my oven is blowing out cold air and while the convention oven is working- it takes a long time to heat up and doesnt cook food as well as the fan assist
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for element How to Repair Home Appliances
Dec 11, 2009 | Candy Ovens
Blower motor not working any speed
Check for the busted fuse at the fusebox labelled
Fan. Hope this help.
Sep 23, 2009 | 2001 BMW 325
Candy cic60
check power supply, outlet both sides voltage, cord for continuity, junction where cord attaches to machine. If there are no faults found here then element is most likely bad," it can be tested for continuity to verify before removing.
Apr 26, 2009 | Dryers
Jun 01, 2008 | Candy CDC266 Dryer
Candy cic60 01 condenser dryer
check the vent line it may be cloged or bent if this is good then possibly the hi temp sensor may be bad ?
Nov 15, 2007 | Candy CDC266 Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
