Question about Legrand adorne 700-Watt Single Pole 3 Way Universal Softap Dimmer -
Lights do not dim
Electrician just installed switch and the lights (7) on the switch don't dim. The bars go up and down but no change in lighting. I've reset by throwing circuit breaker. Could neutral not be wired back to main box?
Light on ceiling fan is very dim. Do not have dimmer switch. Changed bulb but light is still dim. Could something be wrong with the fan?
If it has a remote, press down on the light button and keep it pressed down until your light gets to full brightness.
Apr 25, 2015 | Minka Aire Ceiling Fan
Dim lights don't work
Change the dim switch, and check the fuse
Mar 30, 2013 | 2001 Volkswagen Beetle
Engine shut down on freeway. Good battery, low oil but engine not seized, start relay clicks, but when key turned, nothing-headlights don't dim, idiot lights don;t dim, Nothing. 1997 Toyota Tercel
low oil boiling water sometime automatically stop the engine for further damage. stop the engine wait for sometime. fill up oil/water. check fuse/switches for engine/lights/dimmer. re start.
Oct 04, 2009 | 1997 Toyota Tercel
Interior light comes on when I use the turn signal
it could be an earthing fault or more seriously burnt wiring you need to get it checked out by an auto electrician
Aug 02, 2009 | 2002 Jeep Liberty
Dimmer switch is not dimming
florecent bulbs wont dim unless they are dimmable.
Dec 24, 2008 | Lutron ELECTRONICS CO. Q-603PH-WH "QUOTO"...
Legrand adorne 700-Watt Single Pole 3 Way Universal Softap Dimmer - Logo
87 people viewed this question
Top Legrand adorne Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Legrand adorne Electrical Supply Expert? Answer questions, earn points and help others
