Question about Vacuums
When if the moon full each month
Our baby is due any day now I my family says it will come on the fullness of the moon
    Genius:
  • Vacuums Master
  • 1,198 Answers
The full moon varies when it arrives. A blue moon is the second full moon in a calendar month. The full moon has nothing to do with when you will have your baby.
Posted on Apr 02, 2014
My vacuum is an Electrolux model el 20 the power head stopped working and has a flashing red light on it now
No Owner's manual? Try manualslib.com
But wild guess is the filter bag or possibly the secondary filter is
full. Sometimes. the effect of the full bag will pop open the latch for the filter bag and as a result, will automatically stop. Otherwise, it may be that the motor has overheated as a result of the full filters and stopped due to the overheating.
Mar 26, 2015 | Electrolux Vacuums
How does the moon affect earth
The moon is larger than moons of other planets and helps slow the earth to have 24 hours days that we know. It gives us the tides. It protects earth from asteroids or other dangers
Nov 25, 2013 | Vacuums
My Electrolux Guardian canister vacuum is not sucking it is blowing out. What can I do?
The vacuum won't blow out unless the hose is connected to the exhaust port on top of the canister.
Your problem is most likely due to the brushes running and kicking debris back out.
Loss of suction can be the result of several things, some of which will cause the vacuum to shut off.
Check afterfilter to ensure it's clean. It's located beneath the tool caddy/air diffuser on the back of the vacuum. To open the caddy, press in on tab at back and lift off. There should be a white filter on the exhaust port. If it's highly discolored or hasn't been changed in the last six months, it's time to do so.
Check the hose, wands, and power nozzle for clogs. The wands and PN can be checked visually by holding them up to light. To check the hose, hold up one end, drop a coin or marble in the end, lift the hose allowing the object to drop through.
If the bag full switch isn't working, the bag could be full. Replace it.
Make sure the both the vacuum motor and pn motor are working. If the vacuum motor is not, it could be due to the above problems, worn or broken switches/wiring, and even a bad motor.
You may need to take it to the Aerus Electrolux shop for diagnosis and repair.
http://www.aerushome.com/storelocator/
Feb 27, 2011 | Electrolux Vacuums
I just bought a Miele s558 Silver Moon, seems like
good vacuums bags are very expensive and parts too
return it
May 11, 2010 | Miele s558 Silver Moon Vacuum
When to recharge batter
hi right to be honest both ways are correct, but if your using it every day then its best to put it back on the charger after every use, but the problem with this is that the battery never goes totally flat, so never does a full recharge this reduces the life of the battery by upto 50% so if you are using it regular and need it charged daily then its best to once a month let the battery go totally flat so that it wont even make a sound then do a full recharge.
Doing this will ensure the battery remains at peak performance and make it last longer.
If how ever your only using it say once a week then its best to only charge after the battery has gone flat due to the fact that it would remain on charge longer and cause the battery to over heat reducing the life span of the battery.
But witch ever method you use always let the battery go totally flat once a month then do full recharge this will prolong the life of the battery and ensure it keeps working at full power.
Let me know if you have further questions ok
Jan 18, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
Vac keeps shutting itself off!? vac bag is clear as is hose and wand
This problem is caused by the static electricity which causes the hose controls to jump back down to the off setting. I have seen this issue on several Silver Moon and Blue Moon models before.
The only way to fix this problem is to purchase a brand new, redesigned hose. The new hose can be purchased here; Miele Electric Hose Miele Part # SES 125
In fact, I'm so sure that this new hose will fix the problem to your Miele, that if you do purchase the hose from GoVacuum, we'll give you a 60 day satisfaction money back guarantee. If this hose doesn't fix your problem, you may return it to GoVacuum within 60 days for a full 100% refund, no restocking fees or shipping charges will be deducted. We'll even include a free return label you can use to return the hose to us at our expense!
If you have any questions, please feel free to send me an email, or request a clarification. I hope this helped you. If you found this solution helpful, please remember to rate this solution as helpful by clicking on the four THUMBS UP icons in the top right hand corner of this solution.
Thanks so much,
Chris Jones
GoVacuum.com
Sep 30, 2009 | Miele s558 Silver Moon Vacuum
Will stop running for no apparent reason. The light stays on and you can amp up the power to restart, but the problem is persistent. The book says to change the filters, which has been done.
Greetings from GoVacuum,
The only way to fix this problem is to purchase a brand new, redesigned hose. The new hose can be purchased here; Miele Electric Hose Miele Part # SES 125 .
Thanks so much,
Chris Jones
GoVacuum.com
Jul 12, 2009 | Miele s558 Silver Moon Vacuum
Blue Moon S658 Miele vacuum problem where suction cuts off. The power light stays on. Sometimes I lose full suction, and other times I just lose partial suction. This shows on the handle by going from...
This is a problem with the circuit board in the SES-125 hose. If you replace the hose, this problem will stop. Unfortunately this is the only solution to this problem.
-R
Mar 05, 2009 | Miele Blue Moon Bagged Canister Vacuum
Miele S514 Solaris Electro - won't turn on
I don't have the exact same model as you guys, but maybe my situation is similar to yours. My Miele Silver moon model won't turn on one day. I took it to a Miele authorized repair shop ( they all offer free estimate on finding the problem first, then they will tell you what the repair cost will be). They said my vacuum cord reel shim was damaged. The damage was caused by over stretching the cord while I vacuumed. According to them the shim is kind of like a clip that holds the cord inside the vacuum. When the shim is damaged, the cords are pulled apart and electricity can no longer pass through. That would expalin why it won't turn on. The repair cost was not too bad, it costed forty-six dollars. I hope this helps.
Jun 06, 2008 | Miele S514 Solaris Electro Plus Vacuum
Vacuums Logo
221 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
