LCD Monitor problems.....
A while ago I noticed my monitor wouldn't come on right when turning my computer on. Thinking it was just the cord I didnt pay much attention to it. However it started getting much worse.... I purchased a new cord thinking that would fix my issues. It Did not! When turning my computer on or even after it goes in sleep mode...my monitor shuts off...you can see a very dull faint screen (start up screen)... ut if I unplug and plug my montior many times it will flicker on ( complete brightness..normal) then flick off a couple times before completely staying on. I have had monitors dye before but this seems very weird to me. Is this a certain sign my lcd is dying??
  • Natasha L
    Natasha L Mar 28, 2014
    Just to add this is a 22in Acer LCD ( Which prob explans my issues as is...ACER)
  • 3,320 Answers
Acer are great products, I have had lots and all worked well.
There are no user serviceable parts on these flat panel's..
Use your warranty if available. This is why buying the extended warranty on expensive electronics is a good policy.
Find a nearby electronics repair shop and get it checked over.
Posted on Mar 28, 2014
  • Natasha L
    Natasha L Apr 09, 2014
    It is much cheaper for me to purchase a new monitor as to use the Warrenty .... after shipping expensies I would be abe to purchase a much larger one. I can not say personily Acer is a great brand, I have not owned many Acer products but those I did have been complete utter garbage next to my Dell/HP things. Thank you for reponse.
Kimi
  • 277 Answers
SOURCE: Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Posted on Nov 20, 2005
jackboy
  • 2985 Answers
SOURCE: the monitor just wouldn't turn on from the sleep mode.....
To amplify ~1 The basic computer motherboard has 'On board Graphics'- that is a graphics ability built into the system This is the 3x5 pin blue socket grouped with the USB PS2 and other sockets in a common panel under the Power Inlet. If the machine has an additional Graphics card this will be the same 3x5 socket duplicated here with a another socket. So try both. You could also check the BIOS settings Bios setting are achieved by pressing delete[ or another key - this will be shown which in the start screen] on the computer as soon as you switch on, where by a crude blue/yellow screen will come up. But you will need the hand book to hand to delve further, Rest assure I do not think it is a Monitor problem- but lack of signal from the computer.
Posted on Aug 10, 2007
  • 26 Answers
SOURCE: Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Posted on Feb 25, 2008
SOURCE: Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Posted on Aug 20, 2008
najah
  • 180 Answers
SOURCE: difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Posted on Jun 28, 2009
Hannspree 28" lcd only has
This is almost certainly a bad monitor and needs to be replaced, I wouldn't even troubleshoot it really. Basically half the screen matrix isn't getting any power most likely.
Some things you can troubleshoot if so inclined.
  • Hook the monitor to another computer (to rule out the current computer as a problem)
  • Replace the DVI cable (to rule out cable) although bad cables will typically cause color lose rather than part of the screen to be missing
Comment back if you need anything else.
Sep 08, 2011 | Hannspree HannsG HG281DP 28" LCD Monitor
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
Blinking blue power light and greenish tint....
Is the monitor still under warranty? (probably only the first 12 months)
Try connecting the monitor to a different desktop/notebook computer, to see if it is fine.
If it is, you have a problem with the video-card in your computer, not a problem with your monitor.
There are "capacitors" inside the monitor, that serve to supply "smooth" and "ripple-free" power to the electronic circuits. If you have "bad" capacitors, they are not doing what they should be doing, which causes the electronics to malfunction.
So, if your monitor is a CRT monitor, it's time to responsibly recycle it, and buy a new one.
If your monitor is an LCD monitor, take it to any TV/video repair shop, and pay them $25 to $50 to "inspect" it, looking for "bad caps". Or, spend that $25 to $50 to buy a new LCD monitor.
May 31, 2010 | eMachines E19T5W 19" Monitor
Cornea CT1700 monitor has no power.
i think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Dec 22, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Model; E 193FPp
The inverter power supply goes bad all the time on that unit. Go to www.lcdrepair.us they have instruction videos on opening the monitor as well as sell parts for that unit.
Jun 20, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Moving Horizontal Lines on LCD Computer Monitor (Windows XP2)
It is possible that what you are seeing is 60 cycles AC hum, but then again it may not.
Perhaps you can try increasing your Screen Refresh Rate to any other setting other than 60 Hertz. (Display Properties/Settings/ Advanced/Monitor)
If that does not work, you may need to check your wirings and/or the power supply of the monitor with particular attention to the filter/power capacitor.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 09, 2007 | Computers & Internet
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
SyncMaster 920n Power Cable (?) Issues
I think my monitor power connector broke too
Sep 29, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
