Question about Compaq HP Presario CQ61-314TU Laptop Screen 15.6 LED BOTTOM LEFT WXGA HD 1366x768
The light charger hole is not on
Don't start up
  • Compaq Master
  • 3,320 Answers
Posting the same thing twice is annoying and counter productive.
Try removing the battery and only using AC power. If the power LED on the power brick does not come on then replace the power supply. If it works with just AC then replace the battery. If it still doesn't work, warranty replace the computer.
Posted on Mar 28, 2014
I just bought a 339 Metal series r/c helicopter and I haven't even used it yet because when I pulgged the charger from the remote up the LED lights would not come on... So I don't know If its...
Leave it on the charger for an hour. The lights can be turned on and off from the remote control. After an hour go through the start up procedure in the instructions.
Dec 25, 2012 | Toys
WHAT IS THE OUT PUT FOR THE CHARGER?
Are you asking what the 110VAC to 12VDC charger puts out to recharge the Vector Jump Start System?
Since it contains a 12VDC battery, it must put out at least 13.5VDC at some amp rate, probably 1.5A or more. Will charge faster at 14.5VDC and even higher amps than 1.5A but I don't have one handy to look at. If you look on the charger for the unit, it will be printed there, otherwise any small trickle charger for autos will work to recharge the unit, just don't leave it on there more than 24 hours as it might overheat the battery.
Aug 29, 2012 | JUMP START SYSTEM
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I have new batteries and charger but batteries will not charge
If your battery is totally flat some chargers see this as connecting to a short and will not charge. If the battery has a charge run it down some, my batteries often don't take much of a charge if any. Does the charger light up.Does the charger have any fuses on its out put wiring. Open the charger up, do you see fuses. When the charger is on do you see any blinking lights. If you get a blinking yellow light when hooked to a battery there is something wrong with the battery. Hope this helps
May 26, 2012 | Pride Mobility Products Health & Beauty
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
I GOT A WA3512 .1 BATTERY REPLACEMENT --AFTER 4 WEEKS, IT IS NOW NOT TAKING A CHARGE. THE RED LIGHT ON THE CHARGER IS BLINKING.
Not only do the batteries go bad, but the chargers as well. If you can, plug in the charger, don't connect the battery to it and test the voltage output with a volt/ohm meter. This should let you know if indeed, the charger is bad. Chargers get hot and don't last forever.
Sep 11, 2011 | Garden
Battery not charging. Orange and Green light on charger. 18V Plus one system
The air holes on the bottom of the batteries are there for the battery to vent. Downside is, these vents can also allow moisture to get in and prevent contacts from letting the battery charge and causing the "defective" display on the charger.
I work on pool and spa equipment and I had dropped my batteries in a small puddle of water where I was working, both went dead immediately and both showed "defective" on the charger even after drying them out for a few days.
Tried using a can of air and gave each of the vent holes several shots... The batteries charged and are now working perfectly.
I'm sure even overnight condensation could be the culprit for a charger to display "Defective"
Jun 24, 2011 | Ryobi Multi-Volt Battery Charger
I just got this from a panw shop, it doesn't work it need a battery and I take it it also need a charger for the battery, where is the best place to get one of each, can I get one from the factory, along...
OK, first it doesn't need a charger. Most charger are external types. Battery, it probably uses one (1) CR123A which is a three (3) volt battery, or two (2) "AA" batteries which are rated at 1 1/2 volts each. Batteries you can get them every where, Radio Shack, WalMart, Kmart, Sam's, Walgreen's, One Stop Batteries, etc. The average life for the CR123A is about twenty hours of use, and it probably the same for the double "AA's.
Here how this Famous Trails End NV FT300 Monocular work. The monocular has two button-one for on/off, and the other is for the IR luminations.
.WARNING!!!! This a night vision devise will be used at Night! Don't taking a look see at bright lights or using the night vision devise during the day... Light time.
Now the monocular has a build in shut off for to much light entering the image tube. Don't try it, it works. The more times the monocular NV is subjected to bright lights the more it destroys the thinly film cover over the plate. One it gone, new image intensifier tube and the cost will be about $200 plus shipping and handling.If you just have to take a look see in the monocular. Get a couple of optic lens cover that snap on. The front Optic cover drill about 1/16 in hole in the center of the cap, that it. Now you can take the back lens cover and remove it. Turn your monocular on and take a look through the eye piece. It should be green, if not, take it back the Pawn Shop and ask for a refund.
If you don't have lens covers that OK too. Just get in dark room and point the monocular at one of the corners. Don't point it any lights. It will turn green. I will advise you don't test the auto shut off. You don't know who had first, second or even third time, how it was handed and used. stewbison
Feb 06, 2011 | Famous Trails Ariel FT300 Monocular
Open Questions:
See all Compaq HP Presario CQ61-314TU Laptop Screen 15.6 Questions
Compaq HP Presario CQ61-314TU Laptop Screen 15.6 LED BOTTOM LEFT WXGA HD 1366x768 Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
