Question about Cell Phones
Error04:invalid display mode - Cell Phones
My MAC G5 disk utility repair cannot repair selected items
use disk utilty from system disk by restarting computer holding down c key then go into disk utility and try it.
Jan 21, 2014 | Apple Power Mac G5 Desktop
"macro is invalid" is displayed
This error message indicates that the current scene selection mode is not compatible for Macro shooting.
Please check the below figure to view the applicable scene selection modes for the Macro shooting mode.
The macro is not applicable in Landscape, Twilight and Fireworks mode.
You can use other scene selection modes with macro mode.
Thanks for understanding.
I hope the information helpful, if you want any clarification, please let me know.
Mar 14, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
Invalid header
You are seeing the "Invalid Header" message on the LCD display on the T2250 because the pritner is in "boot" mode, which is the firmware download mode and is detecting data being recived is not a correct firmware file.
The most likely cause for this problem is the pritner has defaulted to 'Firmware Download Mode" due to a problem with either corruption to the firmware or damaged / faulty EEPROMS. When print jobs are sent to the pritner the pritner is expecting firmware and recognises the data it is reciving is not correct for a firmware file.
The solutions to this problem are;
  1. Power the printer OFF, disconnect the printer from the computer system, and any external print server (eg JetDirect etc). Power the printer back on, if the error is resolved check the method of connecting the printer to the computer system to ensure there is no damage to cables etc.
    If the printer displays "BOOT" on the display this indicates the printer is in firmware download mode.
  2. If the display reads BOOT first try reloading the firmware you may find details and firmware on the following web site,
    http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=123&Itemid=48&lang=en
  3. If loading the firmware fails this indicates a logic board fault, the main logic board would need to be replaced to resolve the issue
Feb 18, 2011 | Tally T2250 Matrix Printer
FPD1530 (Black) 15 in. Flat Panel LCD Monitor: Screen shows, 'Invalid Mode', followed on next lin...
It means your PC video resolution setting is too high for this monitor to display.
You need to set the resolution to 1024 x 768 @60Hz. Bootup in safe mode (hit f8 during bootup) select VGA support, rest the resolution to 1024 x 768 @60Hz, reboot.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Gateway FPD1530 15" Flat Panel LCD Monitor
Error04
Drum doesn't spin. Check drum motor or related circuit
Nov 01, 2009 | JVC GR-DVL820U Mini DV Digital Camcorder
I can"t turn on macro. When I push the button, I see on the display that macro is invalid.
I have a Sony W120 and had the same macro problem, tried all the "solutions" mentioned here without result. So I pressed the "Home" button, went to "Settings" (last menu item at right), then "Main Settings", and used the "Initialize" functio. Problem solved !
May 05, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Starret 734 Caliper will not power up
OK, I fixed it! After hearing back from Starrett, it seems that a RENATA battery is the only one that fits right. I went out to Radio Shack and checked their stock, which turns out to be manufactured by RENATA. The new battey works fine... It did take a try or two to get the display cleared, then Error04, now it's working again.
--David--
Mar 25, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Invalid Dimensions for Graphing and Equation
I suspect you are using the TINspire in TI84PLUS mode (with the TI84 keyboard).
If that is the case, the simplest procedure is to turn off STATPLOTS.
Press [2nd][STATPLOT] [4:PlotsOff][ENTER]. Calculator displays Done.
Hope it helps.
Nov 12, 2008 | Texas Instruments TI-Nspire Graphic...
Macro
Conversion Lends Function is Off.
Feb 06, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
