Question about Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC
How can I use Pointer in C++?
I have problem with using pointer in C++, Can anyone know How can I use it?
    New Friend:
There is a very in depth discussion on how to use pointers located here http://www.cplusplus.com/doc/tutorial/pointers/
Posted on Mar 30, 2014
A circle with a line going through it takes the place of my cursor on my computer?
Firstly, go to
Control Panel
Find Mouse
Click Pointers along the top
Ensure that your default pointer is the normal mouse, like so:
If not, press "Use Default" and it should reset the mouse pointer to normal.
If it looks like the mouse pointer is supposed to be normal in this screen, let me know and we'll see if there's something else wrong.
Dec 23, 2012 | Computers & Internet
While charging my laptop , mouse pointer cant work and while it is running on batteries mouse pointer works
hi
remove the battery from your notebook -- use the Ac adapter only
will the mouse pointer work ? are you using an attched wirelss mouse or the palmrest pointer ?
let me know what OS you use -- and if its mouse you use, what model ?
look forward to helping you resolve the issue !
Nov 03, 2010 | Dell Inspiron 1525 Notebook
My cordless optical mouse is slow dragging across the screen. When first used it is fine but then slows down. Ideas anyone?
Try this...
Go to Control Panel > Mouse > Pointer Option
There you can increase the pointer speed/motion.
I hope this helps. If not please inform me. I will see what else I could do.
Jan 30, 2010 | Logitech 9313960403 Mouse
How to write a record with pointer variables in a file in c++
if understand your question correctly , you don not work the pointer value but the contents the pointer is referring to.
Hope that makes sense
char* pointer = "some message";
pointer = 0x04556 *pointer = "s";
Regards
GeWiz
Apr 13, 2009 | Intel Computers & Internet
Keyspan remote control (mouse) Model TSAM - 004
Press and hold the two buttons (small pink and clear pie shaped) for 4 seconds. the lower button will flash red once every three seconds to show laser pointer enabled. Laser pointer turns itself off after 10 minutes on non-use.
Jan 13, 2009 | Keyspan Presentation Remote Control
Laptop mouse
Go to Start --> Control Panel --> Mouse.
Click on the Pointer Options tab and adjust the slider for the pointer speed.
Regards,
Javabytes
Nov 16, 2007 | HP Compaq Presario V2000 Notebook
Fuzy pointer
HI NIXnerd, If your getting a crosshatched or disrupted box around the pointer then it sounds very much like the pointer accelerator is on it's way out. The pointer is displayed by a sub-unit of the GPU, you can think of this as a mini graphics chip built in to the GPU that is there for the sole purpose of displaying the pointer. Sounds like you know what you're doing re: configuring X so try turning off pointer acceleration and see if it makes a difference, sadly if the pointer accelerator is indeed on it's way out then the rest of the GPU will not be far behind so turning off acceleration should be thought of as a temporary solution. As ever, if you have any questions or need more in-depth help post back.
Aug 23, 2007 | XFX GeForce Fx5700 (128 MB) Graphic Card
Open Questions:
how to write c/ c++ sourcecode for Merkle-Hellman Knapsack Public Key Cryptosystem ??? In this problem you will implement the Merkle-Hellman Knapsack cryptosystem. The encryption and decryption algorithms are based on solving a knapsack problem. The knapsack problem consists of finding a way to select some of the items to be packed such that their sum (the amount of space they take up) exactly equals the knapsack capacity (the target). Formally the knapsack problem is as follows: Given a set S = {a1, a2, ..., an} and a target sum T, where each ai >= 0, is there a selection vector V={v1,v2,...,vn} each of whose elements is 0 or 1, such that (ai*vi) = T. The idea behind Merkle-Hellman scheme is to encode a binary message as a solution to a knapsack problem reducing the cipher text to the target sum obtained by adding terms corresponding to 1s in the plaintext. That is, blocks of plain text are converted to knapsack sums by adding into the sum the terms that match with 1bits in the plaintext as shown below: Plaintext: 1 0 1 0 0 1 Knapsack: 1 2 5 9 20 43 Cipher text: 49 Plaintext: 0 1 1 0 1 0 Knapsack: 1 2 5 9 20 43 Cipher text: 27 The receiver will have to use the cipher text (the target sum) to recover the plaintext. A knapsack problem is said to be ``easy'' if {missing}. The solution for the easy knapsack problem is straightforward, and can be achieved in O(n).Furthermore, there exists a way for transforming an easy knapsack set S into a non-easy knapsack H simply by multiplying the elements of S by w mod n where w and n are well chosen integers. Formally the terms of H are: hi = (w*si) mod n. For example if S = {1, 2, 4, 9}, w = 15, and n = 17 then H = {15, 13, 9, 6}. Encryption algorithm (executed by the sender) H is called the public key and is made public by the receiver Choose w and 1. n such that n > max(S) and n is prime, and w < n. Construct H from S, w, and n. Sender uses H to encipher blocks of m bits P0 = [p1, p2...pm], P1 = [pm+1, pm+2...p2m] and so forth (m is the number of terms in H), as follows: Ti = Pi*H = (pj*hj). Thus T0 = P0*H, T1 = P1*H and so on. Ti are then transmitted to the receiver via a reliable channel. 1. Decryption algorithm (executed by the receiver) The tuple (S, n, w) is called the private key and is kept secret by the receiver Use w and n to compute w-1 where w-1*w = 1 mod n. if n is prime then w-1 = w (n-2) mod n 2. Compute Ai = w-1*Ti mod n 3. Find Pi by solving Ai = Pi*S Input file The input consists of N test cases. The number of them (N) is given on the first line of the input file. Each test case begins with a line containing a plaintext to be encrypted. The second line contains the number of elements (m) in the knapsack S that show in the third line. The knapsack elements are positive integers separated by space. The fourth line of each text case contains n and w in this order separated by space. Output file Print exactly 3 lines for each test case. The first line should contain the encrypted values of the plaintext of the set separated by space. The second line should contain the plaintext obtained by applying the decryption algorithm to the plaintext, preceded by `Recovered plain text: '. The third line should contain the value of w-1 Sample Input 2 Salaam! 4 1 2 4 9 17 15 hello there? 4 1 2 4 9 19 7 Sample Output 29 25 22 16 22 28 22 16 22 16 22 44 9 16 0 24 Recovered plain text: Salaam! 8 23 7 23 20 23 21 23 21 23 36 9 0 29 14 23 7 23 20 29 9 23 20 15 36 0 16 Recovered plain text: hello there? 11
Feb 24, 2009 | Borland Turbo C++ Suite 1.0...
Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC Logo
164 people viewed this question
Top Borland Computers & Internet Experts
Tony
k24674
Robin Hill
Robin Hill
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
