Question about HP LaserJet M1120 MFP All-In-One Printer
When i turn on the machine on the screen is showing the initializing messsage only
Initializing
  • 78 Answers
Reseat connectors on the formatter and if that doesn't work replace it.
Posted on Apr 15, 2014
How to fix samsung washing machine model TORNADO 7.0kg WA90B error
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
Nov 01, 2012 | Washing Machines
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
Error E1 samsung washing machine model TORNADO 7.0KG WA90B
-Display Shows 'E1'
Keep me posted!
I can not access my main line
If a system defaults programming it assigns only lines 1 and 2 to each set.
You either had this issue or somebody removed line 3.
Call a tech in to program.
Aug 01, 2012 | NorStar Meridian M7310 Phone
Minolta Copier's sorter bin won't close properly.
This 20 bin sorter uses an interlock switch and actuator to show that the sorter is properly attached to the machine. Pull the sorter away from the machine and look at the rear side of the copier that faces the sorter. There should be what looks like a spike mounted to the copier. That spike goes into a hole in the sorter which then actuals the switch. Make sure the spike is not broken or loose. Make sure the tray that the sorter sits on is not bent. Correct any issues with these 2 and you should be good to go.
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
Upon startup of game get this error message- "unable to initialize video mode: could not set screen mode."
try download n install latest driver..
Here is something you can try for now:
Many games provide an option to be started in "window"-mode instead of fullscreen.
Open a terminal, cd to the directory where the game is installed and start it from there, but append "--help" behind the command name (or "-h" if that didn't work)! Keep an eye open for an option that looks as if it starts the game in window-mode.
Jul 24, 2009 | Atari Desperados 2: Cooper's Revenge for...
PS3 will not show on screen
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the initial beep and wait for a max of 1 min and initial set up screen should appear
Apr 10, 2009 | Sony Playstation 3 (PS3) Console
VCR shows "PLAY" on machine but doesn't show on TV
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
  • set the TV to Channel 3 (or 4); or
  • set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | GE VG4054 VCR
Not able to print from computer I have an lexmark 4270
Is your printer connected to your PC? Is it plugged in and turned on? Is paper and ink properly loaded? If all is ok, try this: Shut down your PC and printer. UNPLUG PRINTER FROM pc and wall outlet. Turn on PC and wait until it is fully initialized. Plug the printer into wall outlet and turn it on. Connect printer to PC via USB cable. The PC should display a NEW HARDWARE FOUND messsage. Next, your PC will try to install the printer by searching for the proper driver for it. If no driver is found, you can download it from http://support.lexmark.com If you have the printer installed, try the following: On your windows screen, left click START. Left click on CONTROL PANEL, and left click on PRINTERS. Find your printer icon in the PRINTERS window and RIGHT CLICK on the printer icon. From the drop-down window, make sure that PAUSE PRINTING is NOT checked off. Next, left click on PROPERTIES at the botom of menu. In the PROPERTIES WINDOW, GENERAL tab, left click on the PRINT TEST PAGE button. If it does not print, try following the on-screen troubleshooting instructions.
Aug 09, 2008 | Lexmark Office Equipment & Supplies
Gaggia Syncrony- "Decalcify" message- what do I do?
If the decalcify messsage continues to appear after you've descaled, press the ESC button for 3 to 5 seconds to clear the message.
Feb 12, 2007 | Gaggia Syncrony Espresso Machine
HP LaserJet M1120 MFP All-In-One Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
