Question about Hampton Bay Dryers
My Hampton Bay fan instlled on a slopped cielling on High speed I hear TIC TIC TIC when I rduce speed o MED no more TIC TIC what is the solution. Does the model 459-664 can it be installed on a sloppe
My fan when I put it on High speed can work well for hours. But sometimes without any reason during the operaton of the fan it starts to make this noise TIC TIC enough to wake me up. I reduce the speed of the fan & the problem stops!!!!!
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
What do you expect to get from a store brand fan? They're cheaper because they use lower end parts. Always look for a fan with at least a 13 degree blade pitch for better air movement.
Posted on Mar 28, 2014
Soulvisitor
  • 1113 Answers
SOURCE: Hampton bay Fan 54 in
Sounds to me like the wall switch is faulty, replace with new or to prove that Im right, switch them and see if problem moves to other fan.
Posted on Dec 30, 2007
  • 178 Answers
SOURCE: HI speed on my Hampton Bay ceiling Fan.
If you are looking to lower your fan speed, I suggest getting an adjustable wall switch that will limit the current to the settings. I have the same situation, I myself didn't do it but I know it is possible. In my bedroom, I have my ceiling fan wired to a turn knob switch, a dimmer so to speak, that limits the elctrical current, thus slowing the rpm's of the fan blades.
Posted on Mar 16, 2008
jasons659
  • 5 Answers
SOURCE: HAMPTON BAY CEILING FAN MODEL # UC7067RC
I have a solution for you. Call 1-866-600-FANS(3267) and give them the numbers on the side of the receiver. Example: 7067FM-22 (6+5) Variations of this receiver are used by many different manufacturers including Hampton Bay,Emerson,Minka Aire, etc... There is a web site that shows a few examples of this receiver available. http://www.fanmanlighting.com
P.S. It helps to know if your Ceiling Fan has a 2nd light above the fan or reverses direction from the transmitter.
Posted on Jan 27, 2009
Treefrog15
  • 127 Answers
SOURCE: Hampton Bay Windward II Purchased 2002
Most fans have a small rectangular multi-tap capacitor connected to the speed control in the fan. It is likely that this has gone partially bad. The capacitance values are printed on it. Lighting stores and big box hardware stores generally carry replacements.
Posted on Feb 25, 2010
SOURCE: I can't find a replacement fan 3 speed switch for
Hi azwaverid!
I just had a similar problem with my ceiling fan, not sure if I have the same model as you (the fan was in the house when I bought it). I do have the exact same pull chain switch (K.T.E 2035080).
I went to a big home improvement store and the salesman gave me some 3-way switch and guaranteed it would work. The switch had only 3 wires, not 4 like the original. Can you guess what happened next? That's right, their part didn't work.
Being an engineer, I could not admit defeat. I consulted with other engineers I work with, and they pointed me to a "mom & pop" electronics store close to my house. I went to Centennial Electronics in Colorado Springs, CO. The sales staff didn't have experience with this problem, but at least helped me and offered suggestions.
I ended up buying a Philmore Pull Chain Switch for $2.51 after tax. This worked perfect! Just be sure to place the wires in the right slots. On my fan, the following positions and wire colors were: L - Orange, 1 - Yellow, 2 - Purple, and 3 - Blue (I just matched them up the same as the K.T.E. switch colors & positions).
Hope this helps!
Bob
P.s. The exact part I used was:
Philmore No. 30-9152 (UPC code: 0 38975 39152 6). The box says (everywhere you see a semi-colon is a line break): Philmore PULL CHAIN SWITCH; L-1-2-3, L-2-3, L-1-3, L-1-2, PUSH-IN TERMINAL; 6A-125V AC, 3A-250V AC; Made in Taiwan No. 30-9152; LKG Industries - Rockford, IL
Posted on Jul 09, 2010
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
My fan only runs on high. No low or medium speeds. The remote shows low, med and high changes but the fan only runs at high.
Check with another same type remote. If same problem, Check PCB. If all speed wires plugged properly? If yes, problem with PCB.Replace it.
Thanks, helpful?
Jan 18, 2011 | Hampton Bay Heating & Cooling
I need a basic wiring diagram for a 3spd, 3 wire capacitor ceiling fan with reverse slide DPDT switch. The rotary pull chain switch was removed along with the cap, so i do not know how to put a new switch...
Try L-BLACK 1-GRAY 2-BROWN 3-PURPLE. IF THIS COMBO DOESN'T WORK. BLACK WIRE GOES TO L , 123 IS YOUR SPEEDS YOU WILL HAVE HOOK THEM UP BY PROCESS OF ELIMINATION FIGURE OUT WHICH IS HIGH MED & LOW. IT SHOULD BE 1-HIGH 2-MED 3-LOW.
Jul 24, 2010 | Hampton Bay Dryers
Motor will barely run
If it's when you set the remote on med or high, check to make sure the switch on the fan isn't set on low. Turn the remote to high and pull the chain switch to see if it goes faster. Someone may have tried to turn it on or off with the chain, forgetting about the remote. Good luck.
Mar 26, 2010 | Hampton Bay 24002 Ceiling Fan
Fan will go no faster than Low
SPEED MOTER CONTROLLER MAY BE DAMMAGED.
Aug 10, 2009 | Dryers
Hampton Bay Garrison 52" fan stuck on high
nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Jun 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
My Hampton Bay Miramar 60 in ceiling fan, works good on the med setting low and high both go slower then Medium. I have remote control all the other function work okay.
Mine just died!!! Can't get the control in side, and they don't have them in stock at home depot anymore here. OK. All hampton bay fan have a lifetime warrenty... they will take mine back, paid $229, but will only get $106 because they had a close out!!!
Good Luck!! I know I loved my fan, going to miss it beauty
May 05, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Dryers Logo
48 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
