Washing machine diplomat
I have a diplomat Washing machine APM 8542. I was washing and the breaker at the electrical box when down. I activated it but the wash machine just light the panel control but it don't show any message. when I try to switch on or switch off it shows the options but disappear very quickly. I think that could be the minisel card. (546060300 -03).
watugot
  • 290 Answers
SOURCE: Washing machine defaults to clean washer option
Sounds like user interface board. Try unplugging the machine, press power button for 3 seconds, plug machine back in and try again. If this does help, it will probably be a temporary fix. The user interface board is the one mounted directly to the console.
Posted on Sep 25, 2007
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
  • 3 Answers
SOURCE: error code 43 on F& P washing machine
Carefully remove control console, then control board. Take note of which connector came from which terminal! Balance sensor is located under control board. Remove with care. Check that little button (size of pen top or pencil lead) is moving in & out freely. It is spring loaded. If it sticks, replace it. Hope this helps.
Posted on Jun 17, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
SOURCE: sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Posted on Feb 19, 2010
Testimonial: "thanks-- how do you know how much soap is enough?"
My electricity trips when I plug in washing machine. What could be the cause
SHORT IN UR MACHINE, WIRED WRONG FROM REPAIR JOB? OR SHORT IN UR BREAKER AND NEEDS REPLACING, DOES OR IS THE BREAKER THE RIGHT AMPERAGE FOR THE BOX?
Sep 26, 2014 | Hoover Washing Machines
Diplomat washing machine
Try Sliding the Soap Dispenser Drawer Lock to the RIGHT and then pull straight back... It is located under the handle
Mar 03, 2014 | Washing Machines
Washer will not turn on
HELLO.
BELOW ARE STEP BY STEP GUILD LINE ON HOW TO FIX THE PROBLEM OF THE WASHER
Nothing is more annoying when washing your clothes then finishing loading your clothes, only to find the machine is not turning on. There are a few different culprits behind this problem, most of which do not require you to purchase any new items to fix the situation.
1 Inspect the cable running from the washing machine to the electrical outlet to make sure it is connected to the washing machine properly. If the cable is cut or damaged, you need to replace it before performing your next wash load.
2 Find the fuse in the circuit breaker and make sure it is still active. You may have blown a fuse at one point using the washing machine, causing it to not run or turn on. Reset the circuit breaker by identifying the washing machine's circuit (it is written next to the breaker itself) and push the flip switch back in the opposite direction.
3 If you need to change a blown fuse, pull the current fuse out of the circuit breaker. The metal filament inside will be either black or burned through. Find a replacement fuse of the same voltage (the number is printed on the front of the fuse and found at any home improvement store), then insert the fuse back into the fuse's location inside the fuse box.
4 Remove any clothing that is blocking the washing machine door from closing completely, such as sleeves or pant legs tucked in by the joints of the front swinging door.
5 Contact your local repair company if the washing machine is still not working correctly. There may be an internal problem with the machine you cannot see.
Thanks.
Sep 29, 2011 | Kenmore HE2 Plus Front Load Washer
Washing machine was operating machine stoped 10 minutes after operating and will not start water is in the machine it did not drain
Hello, first check if the breaker triped in the electrical panel box (fuse box--old name). If it has not triped a breaker. Unplug your washing machine and wait about 10 or 15 second and replug the washing machine into the electrical socket. Don't turn it on. There should be a reset button. Push the button first, then turn on your washing machine. I hope this works for you. GB...stewbison.
Aug 25, 2011 | LG WM-2277HW Front Load Washer
My washing machine won't start when I close the lid
Check the Outlet. Some have a breaker in the middle. Its a little button that pops out when it's tripped. It could also be a fuse or breaker at the electrical box.
Good Luck
Dec 09, 2010 | Whirlpool Washing Machines
Washing machine flips the fuse box switch
Either the moter is jambed or timer is broken Disconnect power tip machine up and attempt to move belt manuallr it shouls with some resistance
Oct 12, 2009 | Washing Machines
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Jul 20, 2008 | Washing Machines
I have a Diplomat APM 8702 integrated washer / dryer, it has decided to stop working! its been great but does get used alot, the electrics come on, ive checked all the connections inside the machine made...
I have one of these machines. I don't know whether this will be of any help but I had issues of the machine not activating a final spin and the clothes being left sodden once the cycle had finished. The engineer replaced the PCB module at the rear of the unit which fixed the problem. If your APM 8702 is not even starting I'd guess its a motor problem and time for an expensive repair or new washing machine.
Apr 26, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
