Question about Whirlpool GU2400XTPS Built-in Dishwasher
Gu2400xtps tech sheet
Tech sheet
Accu sense Light keeps flashing and dish washer wont do anything. help
Under the dishwasher there is a 'kickPlate " turn the power off to the unit and there are 2 screws holding the kickplate on behind it there is a Book ( Tech Sheet ) that will tell you what the accusense lighting means. I thinks it mean you have a bad heater circuit tho which is either a bad heating element or control board. It could possible be the sump motor assy too.
Any qusetions feel free to ask hope this helped
Phillytech1
Aug 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light keeps flashing washer will not run.
The blinking clean light is an interruption in the dishwasher program that usually indicates a component malfunction. This can also be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Please post back and let me know if you still need assistance.
Jun 24, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Green light flashing wont wash
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Apr 04, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light keeps blinking
The blinking clean light is an interruption in the dishwasher program that usually indicates a component malfunction. It can also be a result of a momentary program glitch as well. If a component is defective, it's most commonly attributed to a heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
Mar 31, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
ADP 951 start light flashing permanently
how many times does it flash there is a pause look for it, there is a tech sheet glued to the lower cover or to the bottom of the tub behind the lower pannel that has the codes discriptions and tests turn off power to it befor removing pannel
Dec 08, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dish washer clean light stays on and it wont do anything else
This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
I have often found this to be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. You will need to refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
"Clean" light blinking...
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
Sep 28, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashing and will not run. only
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
Sep 23, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher
look behind the lower acess panel( toe kick) for the tech sheet, there is aspot cleary labeled "clean light ' blinking 7 times.
Nov 25, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Open Questions:
See all Whirlpool GU2400XTPS Built-in Dishwasher Questions
Whirlpool GU2400XTPS Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
