Question about Hotpoint Ultima WF860 Front Load Washer
My hotpoint wf860 washing machine has no power!
My hotpoint wf860 washing machine tripped the circuit breaker. After the c/b was reset the machine won't switch on at all. The fusein the plug has been checked and it's ok. The socket works ok. But the machine still won't switch on! Any ideas?
  • trevor davies Nov 18, 2012
    mine done the same did you get yours working again
Hi guys
Posted on Jun 16, 2009
Hotpoint ultima wt940 washing machine
Either you dont have a high enough amperage breaker or the motor is going bad
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 10, 2013 | Hotpoint Ultima WF860 Front Load Washer
Washer dryer - dryer not heating up
Before you replaced the element did you test the receptacle for 240 volt? Did you turn off the breaker and turn it back on to reset it in case one side tripped and it wasn't visible?
Nov 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
Where is filter on hotpoint ultima
Disconnect power from circuit breaker or unplug power cord before starting. The filter in the hotpoint aquarius 1200 is in the front bottom side, hidden by a trim panel. Remove the trim panel at the bottom of the front side and find the access at the right hand side. Keep a large flat container ready to collect water from drain filter.
Pl say so if helped
Mar 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
FAULT CODE F-03 ON HOTPOINT WASHING MACHINE WF860
i believe that has to do with thermostat circuit. bad thermostat or wiring
Apr 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
No power to washing machine
Check your circuit breaker first, then check to see if you have power at the socket, test it with a lamp or similar, Then, you need to check, if there IS power at the socket, then you need, to call a service person, to check out the internal failure.
Apr 07, 2010 | Hotpoint Ultima WF860 Front Load Washer
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
My hotpoint wf860 washing machine is stuck on f-12 iv tried switching it off and on but still saying f-12 can you help?
f12 is an electrical connection problem between the 2 circuit boards of the machine. it may be a loose connection or more likely a new power board required.
Feb 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf860
Hotpoint Ultima WF860 Front Load Washer Logo
476 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
