Question about Acer Predator G7760 Desktop Pc Intel Core I7-2600K, Ram 16Gb, Hdd 3Tb, 2X Nvidia Gtx 580, Blu-Ray, Windows 7 Home Premium
I have an Acer predator G77600 running windows 7 it has been running fine until this morning I went to the PC and nothing was on the screen the pc was still turned on, I powered down and re booted but
Acer predator will not boot
  • Acer Master
  • 1,087 Answers
When you turn on the power are there any sounds or lights coming? If not It sounds like a power supply problem, which is quite common. You need to get a tech to check its outputs. A replacement one is not too expensive and fairly simple to fit, but you need advice to get a quality one
Posted on Mar 28, 2014
Testimonial: "The PSU powers up the fan on the cooler spins up the lights on the case power up and I can open the dvd drives ect, one thing if I disconnect the power to the crossfire gfx cards the fans spin faster, I have tried removing all hard drives ram ect and going back to a very basic set up with out any change, the unit powers up but there are not any of the usual clicks ect from the hard drives (normal ones) and the unit stays in a state before it loads the bios and monitor says that it is not connected. I have pressed the clear coms button with out any change."
  • 1 more comment
  • Big Steve
    Big Steve Mar 31, 2014
    The power supply has a lot of outputs, some of which may be working. The fact the monitor says 'it is not connected' shows it is basically 'on' but not receiving a signal. As in Joe's suggestion, try booting into BIOS with the Del key, but I still suspect it is a power or motherboard problem. Sorry I can't help more.
  • brucecopebas Apr 04, 2014
    There is usually a wiring diagram on the Power supply or look it up online to see what the voltages are supposed to coming out of the supply. I sounds to me you either have a bad mother board or you lost 24 volt to the logic circuit. If you have never used a voltmeter be careful as you can cause extreme damage to youself or the computer.
  • Big Steve
    Big Steve Apr 04, 2014
    Glad you put in that last point!
SOURCE: PC is hang up about 5 mins after boot up.
I just recently have reinstalled window XP Prof on Acer Aspire T180 with Window Vista originally. Every hardware works fine. I downloaded all the drivers for Window XP from Acer website. However, the PC just keeps hang up on me after 2-10 minutes after boot up. I have to Power cycles it to get it starts again. Any helps will be appreciated. Thanks
Posted on Aug 10, 2008
Giddion
SOURCE: Acer Veriton 6800 PC Desktop will only beep will not boot.
reseat ram for a fast beeping and disconnect the power supply both the big and 4 pin connectors for 2-5 min plug in and boot. Plus you do not have to have pairs of mem only if you wand double data rate
Posted on Jan 10, 2008
imp_squared
  • 56 Answers
SOURCE: Acer Aspire T180 Won't turn on--
There is a similar problem posted here: http://www.fixya.com/support/t344696-acer_aspire_t180_ub72_not_boot
Unplug all USB devices as it may be trying to boot from a USB drive.
If you don't have USB drives plugged in try booting into the BIOS to see if the computer is booting that far. Restart the computer and keep hitting the DEL button, that should get you into the BIOS.
Posted on Aug 14, 2008
  • 57 Answers
SOURCE: My friends Acer Aspire M5641 has a black screen
sounds like hardware. Either something on the board or the hard drive has failed. You might try putting a windows OS disk into the drive and try booting to see if it will read it and try to boot from CD. I guess it could be video card. Double check all the cables are connected.
Posted on Nov 10, 2009
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Posted on Mar 11, 2010
Why did the careen on the acer aspire V5122p go black after a windows update update
It could be hdd maybe, or just file system. Try to reinstall your os.
Sep 03, 2014 | Acer Aspire One PC Notebook
Price to bye
(2) Acer Aspire Predator AG7750-U3222 Intel Core i7 930(2.8GHz) 12GB DDR3 NVIDIA GeForce GTX 470 Acer Aspire Predator AG7750-U3222 Intel Core i7 930(2.8GHz) 12GB DDR3 1.5TB HDD Capacity NVIDIA GeForce GTX 470 Windows 7 Home Premium 64-bit
  • Intel Core i7 930(2.8GHz...
  • 12GB DDR3 1.5TB HDD Capa...
  • DVD Super Multi
  • Type: Gaming
  • Processor: Intel Core i7 930(2.8GHz)
  • Processor Main Features: 64 bit Quad-Core Processor Turbo Boost Technology up to 3.06GHz
  • Memory: 12GB DDR3 1333
  • Model #: AG7750-U3222
  • Item #: N82E16883103296
  • Return Policy: Computer Replacement Only Return Policy
  • Was: $1,999.99
  • Now: $1,899.99
  • Free Shipping
Jan 12, 2011 | Aspire Acer 7520-5071 Notebook
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
DMI Pool Data, Acer
You need a higher computer specification for Windows 7.
Acer Aspire T310 is design only for Windows XP Home/Professional and Windows 2000 according to Acer Support Page:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT310/AspireT310sp2.shtml
Jan 20, 2010 | Acer Aspire T310 PC Desktop
Acer Aspire One
We have two that went "Dead" like that too. Acer knows all about the problem of losing video. They have a BIOS update that they will send you on a flash drive. Give them a call, have your computer handy to give them numbers and in 3 o 4 days you will e up and running with your Acer One. They are a great little computer. By the way, you will not loose Windows 7 which I am using on my desktop right now. It's better than Vista.
May 28, 2009 | Acer Aspire One PC Notebook
Cannot start up my laptop since in done an update
Try booting into "Last known good configuration" it is on the same screen as Safe Mode, if that does not work, you can try to run CHKDSK /r from the windows install CD, just choose "Repair" in the option, if this does not work I suggest removing that hard drive and slaving it into another computer to get your data off and then reload Windows onto it. It is missing a .dll
Nov 28, 2008 | Acer Aspire 1642WLMi Notebook
Acer Predator G7760 Desktop Pc Intel Core I7-2600K, Ram 16Gb, Hdd 3Tb, 2X Nvidia Gtx 580, Blu-Ray, Windows 7 Home Premium Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
